How Does Double-Paned Glass Affect Heat Transfer?
  • Thread starter Thread starter {~}
    Glass
This discussion focuses on the heat transfer through a double-paned window consisting of two glass panes and an air gap. The thermal conductivity of glass is approximately 36 times greater than that of air, with values of 0.84 W/(m·K) for glass and 0.0234 W/(m·K) for air. The calculated heat flow through the air layer is approximately 26.3 W/m², leading to an estimated temperature difference across each glass pane of 0.157 °C. The exact heat transfer rate for the complete window is 19.1 J/s.
  • Understanding of thermal conductivity principles
  • Familiarity with heat transfer equations, specifically Fourier's law
  • Basic algebra for solving equations
  • Knowledge of temperature measurement and conversion
  • Study Fourier's law of heat conduction in detail
  • Learn about thermal resistance in multi-layer systems
  • Explore the impact of material properties on heat transfer rates
  • Investigate methods for improving energy efficiency in window designs
Students in physics or engineering, professionals in building design, and anyone interested in energy efficiency and thermal management in structures.
1. Homework Statement [/b]
Consider a double-paned window consisting of two panes of glass, each with a thickness of 0.500 cm and an area of separated by a layer of air with a thickness of 1.75 cm. The temperature on one side of the window is 0.00 °C; the temperature on the other side is 20.0 °C. In addition, note that the thermal conductivity of glass is roughly 36 times greater than that of air. (a) Approximate the heat transfer through this window by ignoring the glass. That is, calculate the heat flow per second through 1.75 cm of air with a temperature difference of 20.0 C°. (The exact result for the complete window is 19.1 J/s.) (b) Use the approximate heat flow found in part (a) to find an approximate temperature difference across each pane of glass. (The exact result is 0.157 C°.) (Thermal conductivity of glass is 0.84 W/(m?K) and of air is 0.0234 W/(m?K))
2. Homework Equations [/b]
[tex]\frac{\Delta Q}{\Delta t} = kA\frac{T_{1} - T_{2}}{l}[/tex]
3. The Attempt at a Solution [/b]
This is actually me trying to help someone else on another website and apparently failing
Here's what I got
Part (a)
Equation 19-16a from fourth edition Giancoli Physics for Scientist and Engineers
Our givens
k = 0.0234 W m-1 K-1
T1 - T2 = 20 K
l = 1.75x10-2 m
Leave the unknowns on the left side of the equation and substitute the givens on the right
Note: The m K are part of the themal conductivity units
Evaluate
26.3 W m-2
Notice that this is not the complete answer for (a) because an area was not provided; however, this does not prevent me from completing (b)
Part (b)
I modify Eq 19-16a for a situation of series conduction
Substitute givens
The algebra is a little intense but here goes
We have two unkowns but only one equation. We need another equation to solve the problem.
Lets draw a picture
This problem has symetry that we can exploit
20C - T2 = T3 - 0C
T3 = 20C - T2 + 0C
Substitue and rearange
Note: I divided k and l for neatness
26.3 W m-2 = 168 W m-2 K-1 (20C - T2) + 1.34 W m-2 K-1 (T2 - (20C - T2 + 0C)) + 168 W m-2 K-1 ((20C - T2 + 0C) - 0C)
Simplify
26.3 K = 168 (40C - 2T2) + 1.34 (2T2 - 20C)
Distribute
26.3 K = 6720C - 336 T2 + 2.68 T2 - 26.8C
Evaluate
333 T2 = 6670 K
T2 = 20.0 C
Obviously I screwed up somehow I just can't see where
In case of series connection the current of heat is the same for each element, window-panes and air. Your equation for dQ/dt is wrong.
ehild
  • · Replies 16 ·
12K
