Making Electric Coils & Schumann Resonance
  • Context: High School
  • Thread starter Thread starter Jdo300
    Coils
The discussion revolves around the construction of electric coils that resonate at specific frequencies, particularly in relation to the Schumann resonance, which is associated with the Earth's electromagnetic field. Participants explore the physics of resonance, coil design, and the potential use of capacitors and magnetic materials in achieving resonance.
  • One participant inquires about making an electric coil that resonates at a specific frequency and mentions the Schumann resonance at approximately 7.8 Hz.
  • Another participant suggests that constructing an LC resonant circuit would require a large coil and a capacitor, providing the formula for resonant frequency.
  • There is a discussion about the feasibility of building a resonant coil without a capacitor, with one participant asserting that a capacitor is necessary for resonance.
  • A participant questions whether a capacitor is needed if the resonance is induced by external sources like radio waves, proposing an experiment with a toroidal core and coil that resonates due to ambient energy rather than supplied electrical energy.
  • There is speculation about the effects of placing a magnet near the coil and its potential to influence the resonant frequency.
Participants express differing views on the necessity of a capacitor for resonance, with some asserting it is essential while others explore the possibility of resonance through external sources. The discussion remains unresolved regarding the practicality of achieving resonance without a capacitor.
Participants reference specific frequencies and components but do not reach a consensus on the methods or designs for achieving resonance. The discussion includes assumptions about the behavior of coils and external electromagnetic influences.
Jdo300
Hello, I have kind of an odd question here. I was wondering how to make an electric coil that will naturally resonate at a perticular frequency. I am a novice when it comes to the associated physics so I'm hopeing that someone can explain this to me.
I also have another related question. I heard somewhere that the Earth has an electromagnetic field that resonates at a perticular frequency (I've heard the phenomenia referred to as Schunmen Resonance). Is this in deed true? If so, I wanted to try and make a coil that would resonate with this 'natural' frequency. Any help is appreciated.
There's tons of crank sites about the Schumann resonance, the only halfway decent non-cranky web reference I found was
here
Since it's at 7.8 hz, you would need a very large coil and a big capacitor to construct an LC resonant circuit.
the resonant frequency will be 1/(2*Pi*sqrt(L*C))
You will want 2*pi*f*L to be >> than the resistance of the coil to have a reaonably sharp filter (high Q).
You'd probably be better off with other methods than a physical LC filter if you were seriously interested in studying the phenomenon though. (You can build active filters with op amps at this frequency, you could probably even sample the waveform and use a computer to due the filtering / analysis numerically). Either of these methods will require non-trival electronics knowledge though.
There are some formulas for the inductance of a solenoid
here
as far as your original question goes. You would probably wind the inductor yourself, but buy the capacitor, if you proceed with your original plan.
Hi,
Thank you for your reply. I am wondering, is it possible to build a coil that will resonate at the frequency without the use of a capacitor? And how big a coil would one need to be able to resonate at this frequency? I would ideally like to make it as small as possible but I could use different gagues of wire and such if that would help. Also, would putting the coil on something like a ferromagnetic toroidal core help any? I'm wotking on an oddball project and that's why I mentioned the toroid. The coil would only be wound on part of the core, not all of it.
No. An inductor needs a capacitor to form a resonant tank.
Sorry, that's just the way it works.
Hmmm.. that makes sense I suppose. But just to make sure that I understand this, would a capacitor be needed if the source causing the coil to resonate was from the air (like a radio wave)? THe setup I am making would not need to amplify the signald but just get the coil and the toroid to oscilate back and forth with the frequency of the source. Is it possible to have a sort of inductive oscilator where the only thing really making the coil do anyting is the already oscilaring resonance energy in the air? I'm sure I'm probably explaining this wrong. BUt ultimately, I'm trying to do an experiment where I have a toroid core and a coil that is tuned to resonate at the 7.8Hz frequency, not because of any electrical energy that I supply to the coil but jus from the radio signald in the air causing it. My next test was to see what would happen if I stuck a magnet up to the coil or just somewhere on the toroid core (which would be made of a ferromagnetic material). I heard somewhere that doing this causes the coil to resonate at a higher frequency like a circulator (which I am still learning about).
  • · Replies 17 ·
