What is Einstein Temperature and how can i use it in this question?
  • Context: Graduate
  • Thread starter Thread starter stunner5000pt
Einstein Temperature (Te) is a critical concept in thermodynamics, defining the temperature at which the heat capacity at constant volume of a substance reaches one third of its classical value (3R). The formula to express this relationship is 3R = 3Te^2/(e^(Te/T) - 1). To calculate Te for a specific substance, the frequency of atomic vibrations (nu) must be known, which can be determined using Te = Hnu/k, where H is Planck's constant and k is the Boltzmann constant. Without the specific substance and its atomic properties, calculating the Einstein temperature is not feasible.
  • Understanding of thermodynamics and statistical mechanics
  • Familiarity with the concepts of heat capacity and classical values
  • Knowledge of Planck's constant (H) and Boltzmann constant (k)
  • Ability to interpret and manipulate mathematical formulas
  • Research how to determine atomic vibration frequencies (nu) for various substances
  • Study the implications of Einstein Temperature in solid-state physics
  • Explore the relationship between heat capacity and temperature in different materials
  • Learn about the applications of statistical mechanics in thermodynamic calculations
This discussion is beneficial for students and professionals in physics, particularly those studying thermodynamics, materials science, and statistical mechanics, as well as anyone involved in calculating heat capacities of substances.
stunner5000pt
At what temp will the heat capactiy at constant volume of a substance achieve one third of its classical value of 3R? Express in terms of Einstein temperature Te.
3R = 24.9 J/ mol K
R = 8.314 J / mol K = [tex]3R (\frac{Te}{T})^2 \frac{e^\frac{Te}{T}}{e^\frac{Te}{T} - 1}[/tex]
But i don't know what the Te for a subtance is though? Te = H nu / k
i don't know Nu though...
This question has nothing to do with special or general relativity - it is a problem in statistical mechanics. Try either the classical physics forum, or homework help.
Einstein Temperature is a concept in thermodynamics that is used to describe the behavior of atoms in a solid material. It is defined as the temperature at which the heat capacity at constant volume of a substance reaches one third of its classical value (3R). This temperature is specific to each substance and is related to the vibrational energy of its atoms.
In the given question, the goal is to find the temperature at which the heat capacity at constant volume of a substance reaches one third of its classical value. This can be expressed in terms of the Einstein temperature (Te) using the formula provided in the question: 3R = 3Te^2/(e^(Te/T) - 1).
To use this formula, the value of Te needs to be known for the given substance. Te can be calculated using the equation Te = Hnu/k, where H is the Planck's constant, nu is the frequency of atomic vibrations, and k is the Boltzmann constant. However, the frequency of atomic vibrations (nu) is not provided in the question, so it cannot be used to find Te.
In order to use the Einstein temperature in this question, we would need to know the specific substance and its atomic properties. Without that information, it is not possible to accurately calculate the Einstein temperature and therefore, the temperature at which the heat capacity reaches one third of its classical value.
  • · Replies 131 ·
11K
  • · Replies 0 ·
  • · Replies 0 ·
