Reverse Biasing a Voltage Regulator
The discussion centers on the implications of connecting an external 5V power supply to a microcontroller development board featuring an LM7805 voltage regulator without the wall plug connected. It is established that this setup poses a risk to the regulator, as it may not handle the absence of input voltage properly, potentially leading to damage. A diode is often recommended to prevent reverse biasing in such scenarios. Additionally, alternatives like the Micrel MIC5235 regulator are suggested for applications requiring this configuration.
  • Understanding of LM7805 voltage regulator functionality
  • Knowledge of reverse biasing effects in voltage regulators
  • Familiarity with microcontroller power supply designs
  • Basic electronics concepts, including diodes and capacitors
  • Research the implementation of diodes in voltage regulator circuits
  • Study the specifications and applications of the Micrel MIC5235 voltage regulator
  • Learn about safe power supply designs for microcontroller boards
  • Investigate the effects of reverse voltage on linear regulators
Electronics engineers, hobbyists working with microcontroller development boards, and anyone designing power supply circuits for embedded systems.
Jdo300
Hello All,
Simple question here. I have a microcontroller development board that plugs into the wall and has a garden variety LM7805 type 5V regulator on the board for powering the microcontroller and other peripherals. But also on this board is a header that allows the 5V from the board to power external circuits. My question is, what happens if I connect the 5V pin on the board to an external 5V power supply without the wall plug connected to the board?
In other words, I have a situation where I am supplying 5V to the 5V rail while there is no input voltage on the input side of the 5V regulator. Does it care if there is no input voltage or will this cause damage to the regulator?
Thanks,
Jason O
There is often a diode placed across the regulator to avoid this happening in normal use.
It could happen if there was a charged capacitor on the 5 Volt line and you turned off the input power.
So, yes, this is risky. The plug should probably disconnect the output of the regulator from the 5 Volt line if the 5 volts was going to come from elsewhere.
Plus you are powering all of the internal circuitry of the 7805 with your alternate supply. If it a battery it will drain faster.
There are some regulators that are designed to be operated like you are describing. Micrel MIC5235 for example.
BoB
  • · Replies 16 ·
  • · Replies 38 ·
