Set builder notation question.
The discussion centers on the interpretation of the set S = {n ∈ Z | n = (-1)^k, for some integer k}. Participants clarify that S represents all integers since k can be any integer, leading to n being either positive or negative integers, including zero. The confusion arises from the notation and the role of k, with emphasis on the correct interpretation that every integer can be expressed as n = (-1)^k for some integer k. Thus, the conclusion is that S encompasses all integers.
  • Understanding of set-builder notation
  • Familiarity with integer properties
  • Basic knowledge of exponentiation
  • Ability to interpret mathematical notation
  • Study set-builder notation in depth
  • Explore integer properties and their implications in set theory
  • Learn about exponentiation and its applications in mathematics
  • Practice converting between set-builder notation and set-roster notation
Students of mathematics, educators teaching set theory, and anyone looking to deepen their understanding of set notation and integer properties.
Jim01
Use the set-roster notation to indicate the elements in each of the following sets.
S = {nZ |n(-1)k, for some integer k}
Here is how I read this:
"S is the set of all n’s that are a member of the integers, such that n=(-1)k for some integer k."
I am confused about how to go about indicating the elements in this set. Specifically, how does k fit into the picture? If k can be any integer, then would n not also be any integer? Changing k would change n wouldn't it? If this is true then wouldn't the elements be all integers?
From what you have below, this description should say n = (-1)k. IOW, you have omitted the equal sign.
If I understand what you have described, S is the set of all integers. If k is an integer, then -k is in S. Here k can be negative or positive (or zero). No matter which integer you take for k, such as 3, -5, or 0, -k (equallying, respectively, -3, -(-5) = 5, or 0) is still an integer.
  • · Replies 24 ·
