Graph of f(x) = (x-p)(x-q): Intersections with x-axis
  • Thread starter Thread starter Peter G.
    Graph
The discussion revolves around the graph of a quadratic function, specifically f(x) = (x-p)(x-q), and its intersections with the x-axis. Participants are trying to determine the values of p and q based on the graph's intersections at -0.5 and 2.
  • Participants express confusion about identifying the values of p and q, questioning the validity of the book's provided answers. There is also a discussion about the properties of a different quadratic function represented as ax² + bx + c, particularly focusing on the signs of a, b, and c, and how they relate to the graph's orientation and vertex position.
The conversation is ongoing, with participants exploring different interpretations of the quadratic functions and their characteristics. Some guidance has been offered regarding the relationship between the coefficients and the graph's features, but no consensus has been reached on the specific values of p and q.
Participants note that the problem may lack clarity, as the book provides specific answers for p and q without sufficient context. Additionally, there is uncertainty regarding the value of b in the second function, with conflicting interpretations based on the graph's behavior.
Peter G.
Hi,
The diagram represents the graph of the function: f(x) (x-p) (x-q)
The diagram shows a quadratic graph that intersects the x-axis twice: at -0.5 and 2.
It then asks us for the value of p and q.
I know the answers are: 0.5 and -2
But I am confused on how to determine which is which :mad:
Thanks,
Peter G.
Of course, there is no way to tell which is which !
Yeah, that's what I thought but the book put specific answers for p and q... Not very good question I guess :-p
Oh, and one thing:
The diagram shows part of the graph of the function:
ax2+bx + c
The graph is a upside down parabola fully to the right of the y axis, and its vertex only touches the x axis. It then asks:
The value of a, c, and b - Whether they are positive or negative.
Value of a: Negative because the curve is upside down
Value of c: Negative because it cuts the y-axis below the x axis
Value of b: I am confused with this: I tried playing around completing the square several times and as I increased the value of b, I increased how much it moved to the left or right. Furthermore, if my value of b was positive, within the perfect square, the value was also positive, so I concluded. If the graph moved to the right, my value within the brackets should be negative but the book says positive, could you explain?
Thanks
The x-coordinate of the vertex is -b/(2a).
So b must be positive the vertex is in a location (to the right of the y axis) where the x values are positive? b must be positive because we have a as negative and the result of the multiplication must be positive?
Yes.
Ok, thanks once again.
9K
