Step Up Transformer: Using an Alternator to Increase Voltage
  • Thread starter Thread starter jaredogden
    Transformer
The discussion centers around the feasibility of using a step-up transformer to increase the voltage output from an alternator, particularly in the context of charging batteries. Participants explore the implications of voltage increase, including practical applications and considerations related to conductor size and costs.
  • Exploratory, Technical explanation, Conceptual clarification
  • Some participants confirm that it is possible to use a step-up transformer with an alternator to increase voltage, specifically referring to AC systems.
  • One participant suggests that the increase in voltage depends on the number of turns in the transformer coils, indicating a relationship between turns and voltage output.
  • Another participant mentions practical applications, such as using an alternator to charge multiple batteries, and highlights the importance of considering the operating voltage for efficiency and cost.
  • There is a note that while higher voltages can reduce conductor size, they may incur higher costs due to the need for better insulation.
  • One participant points out that there are optimal operating voltages based on factors like copper prices and safety, suggesting that voltages like 110V or 230V are common for domestic supplies, while 12V is often used for battery charging.
  • Another participant emphasizes that the limit for step-up voltage is determined by the specific transformer rating and the desired output voltage.
Participants generally agree that using a step-up transformer with an alternator is feasible, but there are multiple perspectives on the optimal voltage levels and practical considerations, indicating that the discussion remains somewhat unresolved regarding the best practices.
Participants mention various factors influencing voltage choice, such as conductor size, insulation costs, and battery charging efficiency, but do not delve into specific calculations or detailed technical specifications.
jaredogden
Is it possible to use a step up transformer to increase the voltage delivered by an alternator? If so how much can you increase the voltage just depends on how many turns the copper has or what?
If your refer to AC then sure. What is the context of your question?
Yes I was referring to AC. I was meaning it in the context of using an alternator to charge multiple batteries say hooked up to a stationary bike or something.
That's perfectly possible. Its actually what's done all over the world. But remember, the Higher the voltage you use, although the conductor size decreases, you will be paying higher due to added cost of insulators.
There's usually some optimum operating voltage, based on copper prices and safety. 110 or 230V are good choices for domestic supplies but lower volts afe good for charging batteries as the current won't be all that high.
There's a lot to be said for using 12V because that's a common voltage for batteries and you can usually charge a number of batteries in parallel (you may consider blocking diodes to prevent batteries discharging into one another).
Its possible to use step up transformer to increase the voltage delivered by an alternator. You only decide the limit for your step up voltage. Just search in the market about what rating of transformer is available and what is your output voltage requirement.
  • · Replies 18 ·
  • · Replies 27 ·
