How can the Extended Euclidean Algorithm be simplified for faster computation?
  • Context: Undergrad
  • Thread starter Thread starter SirEllwood
    Algorithm Euclidean
The discussion focuses on simplifying the Extended Euclidean Algorithm for faster computation, specifically in finding the coefficients for the equation ax + by = 1. The example provided demonstrates the algorithm's steps to derive the greatest common divisor (g.c.d) and the corresponding linear combination. A participant seeks clarification on how to achieve the same results more concisely, as their method involves more steps. The response clarifies that by working backwards from the final equation, one can substitute previous results to streamline the process.
  • Understanding of the Extended Euclidean Algorithm
  • Familiarity with Diophantine equations
  • Basic algebraic manipulation skills
  • Knowledge of modular arithmetic
  • Study the process of back substitution in the Extended Euclidean Algorithm
  • Learn about Diophantine equations and their applications
  • Explore modular inverses and their computation
  • Practice simplifying algebraic expressions for efficiency
Students and professionals in mathematics, computer science, and cryptography who are looking to optimize their understanding and application of the Extended Euclidean Algorithm.
SirEllwood
Hi all, ok so below is an example of the Extended Euclidean Algorithm, and i understand the first part perfectly to find the g.c.d.
701 − 2 × 322 = 57,
322 − 5 × 57 = 37,
57 − 37 = 20,
37 − 20 = 17,
20 − 17 = 3,
17 − 5 × 3 = 2,
3 − 2 = 1,
and
1 = 3 − 2
= 6 × 3 − 17
= 6 × 20 − 7 × 17
= 13 × 20 − 7 × 37
= 13 × 57 − 20 × 37
= 113 × 57 − 20 × 322
= 113 × 701 − 246 × 322.
Now on the second part, it is finding the equation of ax +by = 1, which i am generally having to find so i can compute the inverse of a(modb). They have managed to do this in 7 steps. It always takes me like more than twice as many in a really longwinded fashion. Has the example below missed out some steps for the sake of conciseness? I just don't understand how they are doing what they are doing.
For example I would have said
1= 3- 2
1 = (20-17) - (17 - (5x3))
1 = ((57-37) - (37-20)) - ((37-20) - 5(20-17))
etc.
Which is obviously far more longwinded, but equally as methodical. I want to know how to do this more concisely so in an exam it would be far less confusing and time consuming.
Thank you!
Hi, "Sir", :P
yes, the second part looks abridged. This is how it would work:
You use the lines in the first part in reverse order, bottom to top. The bottom line says
1 = 3 - 2
(which is a Diophantine equation equal to 1, as required) so you just copy it. Now, each successive line of the first part gives an equation for a number, that you can substitute in the second part. The next one (bottom to top) on the first part says
2 = 17 - 5 x 3
and, substituting in your current Diophantine equation for 1, you get
1 = 3 - 17 + 5 x 3 (and, grouping the terms in 3 together,)
= 6 x 3 - 17
The next equation will give you an equation for 3 in terms of 17 and something else, so you'll be able to substitute, and then group the terms in 17 together. See how it works?
Hope this helps--
