Cartesian product help?I'm interested how to solve the following problem:
  • Context: Undergrad
  • Thread starter Thread starter Chuckster
    Cartesian Product
The discussion revolves around a mathematical problem involving a triangle with sides a, b, and c, where the relationship (a+b+c)x(a+b-c)=3ab is given. Participants are trying to determine how to find the angle opposite side c using this equation, exploring the implications of the notation and the cosine rule.
  • One participant expresses confusion about the meaning of the equation (a+b+c)x(a+b-c)=3ab, questioning whether a, b, and c are numbers or vectors, and what the notation signifies.
  • Another participant suggests using the cosine rule, stating that the angle opposite side c can be found using the formula c^2=a^2+b^2-2ab\cos(γ), but is unsure how to apply it given the lack of numerical values.
  • A participant proposes expanding the expression (a+b+c)(a+b-c) and substituting the cosine rule to find a solution.
  • There is a mention of a potential misunderstanding regarding the notation, with a participant initially thinking that 'x' might indicate a vector product, but later clarifying that it is simply multiplication.
Participants express confusion and uncertainty about the notation and its implications, with no consensus reached on how to interpret the equation or its relevance to finding the angle.
Participants have not established the definitions of the variables or the notation used in the equation, leading to ambiguity in the discussion. There are also unresolved assumptions regarding the values of the sides and angles of the triangle.
Chuckster
if we have a triangle, where a,b,c are sides of that triangle and we know that
(a+b+c)x(a+b-c)=3ab, we need to find the angle opposite to side c.
How to do this?
I have no clue what (a+b+c)x(a, b, -x)= 3ab means. Are a, b, and c numbers or vectors? What does "(a, b, -z)" mean?
i messed up the post. check the edited version.
Hello Chuckster! :smile:
You still have not explained what (a+b+c)x(a+b-c)=3ab means. Are a,b,c just numbers and is x the regular multiplication? Also, what does the Cartesion product have to do with all of this?
When given three sider a,b,c, you can always find the angle opposite to c (called [tex]\gamma[/tex]) by the cosine rule:
[tex]c^2=a^2+b^2-2ab\cos(\gamma)[/tex].
I really have no clue what (a+b+c)x(a+b-c)=3ab has to do with this though...
I know the law of cosines, but i can't find a way to use it here, because i don't know the numerical values of the pages, neither do i know the angles.
I just know i have the condition given that
(a+b+c)x(a+b-c)=3ab.
I'm guessing that x marks the Cartesian product of a+b+c and a+b-c and is equal to 3ab.
But, that doesn't sound logical or reasonable to me.
Did you try by expanding (a+b+c)(a+b-c) and then substitute
[tex]a^2+b^2-c^2=2ab\cos(\gamma)[/tex]
Try if you can do something like that...
actually that was the key to solving this, but i found a version of this task where it said
(a+b+c)X(a+b-c), and i was in doubt what X means, and i thought it was a vector product.
however, it turned out to be just simple ol' multiplying.
  • · Replies 33 ·
