Why does the voltage across R1 increase when the BJT is turned ON?
The discussion revolves around the behavior of a BJT in a voltage divider circuit, specifically focusing on the increase in voltage across a resistor when the BJT is turned ON. Participants explore the implications of this behavior in the context of circuit design and simulation results.
  • One participant describes a circuit design involving a 3-resistor voltage divider where a BJT shorts the center resistor based on the input voltage.
  • Another participant calculates the current through a resistor under different conditions, noting an increase in current when the BJT conducts.
  • A suggestion is made to consider using a bilateral switch instead of a BJT, highlighting the characteristics of a specific device (NTE6403) that could be suitable for the application.
  • Several participants express confusion about the observed increase in voltage at the emitter when the BJT is turned ON, with one noting that even under ideal conditions, an increase in voltage across a resistor is expected.
  • One participant reflects on their simulation results, indicating that the voltage increased more than anticipated, attributing this to the base voltage of the BJT being influenced by the op-amp output.
Participants generally agree that the voltage across the resistor increases when the BJT is turned ON, but there is no consensus on the exact behavior or expected values, leading to some confusion and differing interpretations of the simulation results.
Participants mention the influence of the op-amp's current limit on the voltage readings, indicating that the simulation software's modeling may affect the results. There is also an acknowledgment of the assumptions made regarding the ideal behavior of the BJT.
likephysics
I am trying to design a 3 Resistor voltage divider. The center resistor is shorted out using a transistor depending on the input voltage.
If Vin is <1, then center resistor is not shorted.
If Vin is >1 then center resistor is shorted by the BJT, so only the top and bottom resistor will act. (ignoring Vce sat).
But when I simulate, the voltage at the emitter increases when the BJT is turned ON.
I don't understand why.
In the attachment, Vin goes to the +Ve terminal of the buffer.
If the transistor was not conducting, the current through the 100 ohm resistor would be
8 volts / (1K + 2K + 100 ohms ) or 2.58 mA.
If the transistor did conduct (and was perfect), the current through the 100 ohm resistor would be 8 volts / (1 K + 100 Ohms) or 7.3 mA.
So, the voltage across the 100 ohm resistor would increase to 0.73 volts from 0.258 volts.
Instead of the transistor, perhaps you could use a bilateral switch. It is just a thought and you may not even want to consider one. Any way this one (and there are many others) has the following description:
The NTE6403 is a silicon planer, monolithic integrated circuit having the electrical characteristics of a bilateral thyristor. This device is designed to switch at 8 volts with a 0.02%/°C temperature coefficient and excellently matched characteristics in both directions. A gate lead is provided to eliminate rate effect and to obtain triggering at lower voltages.
The NTE6403 is specifically designed and characterized for applications where stability of switching voltage over a wide temperature range and well matched bilateral characteristics are an asset. It is ideally suited for half wave and full wave triggering in low voltage SCR and TRIAC phase control circuits.
http://docs.google.com/viewer?a=v&q...w63ny&sig=AHIEtbQPDXDZ9Zcku--1UREu2yNJLg7PQQ"
As vk6kro already pointed out, even if the BJT behaved like an ideal switch in this circuit then you'd expect the voltage across R1 to increase (from .26 volts to .73 volts). I don't see how you could be expecting otherwise.
Now what I think you really meant to say was that the voltage across R1 increases by more than what you expected. That's what I would expect to happen with this circuit. The exact value will depend upon how well your software models the opamps current limit but I'd expect the voltage to rise to about 3 or 4 volts (instead of to the expected 0.73). Is that what happened?
Yup, it increased by 3 to 4v.
Soon after posting, I realized, it was bcoz of the base voltage. The emitter( or R1) was only 0.7v less than the base voltage. Base voltage is nothing but op amp output voltage.
Thanks Vk6kro, dlgoff.
I think a switch is better than BJT.
11K
  • · Replies 20 ·
