How do you check that Colour is Conserved?
  • Context: Graduate
  • Thread starter Thread starter DoubleHelix
    Colour
The discussion revolves around the conservation of color charge in particle interactions as described by the Standard Model of particle physics. Participants explore how to determine if color is conserved during various processes, considering the implications of baryon number conservation and the nature of observed particles.
  • Exploratory, Technical explanation, Debate/contested
  • One participant queries how to check for color conservation, suggesting that colors can be assigned arbitrarily and questioning if a lack of valid combinations indicates impossibility.
  • Another participant asserts that as long as baryon number is conserved, color conservation will naturally follow, implying a consistent color assignment is sufficient.
  • A third participant explains that observed particles are color singlets due to SU(3) color gauge symmetry and Gauss law, indicating that color non-conservation would require the existence of asymptotic colored states that do not sum to zero in total color charge.
  • A later reply expresses appreciation for the clarifications provided by others.
Participants express differing views on the necessity of color assignments and the implications of baryon number conservation for color conservation. The discussion does not reach a consensus on how to definitively check for color conservation.
Limitations include the assumption that baryon number conservation guarantees color conservation, which may not be universally accepted. The discussion also highlights the complexity of color charge interactions and the conditions under which color non-conservation might be observed.
DoubleHelix
I'm asked to examine a set of processes and determine if they are possible/impossible according to the Standard Model. So I have to check that energy, baryon number, color, lepton number, quark flavor and the symmetries are conserved. I'm fine with all of these but how do you go about checking if color is conserved? I thought the colors could be assigned arbitrarily so is it just if you can't find a combination that works is it impossible?
e.g. proton + anti-proton -> pion(+) + pion(-)
ignoring the other conservation laws for now, you know (or can atleast deduce) that quark combinations of each particle (where a particle in brackets in an anti-particle or anti-color),
uud + (u)(u)(d) -> u(d) + (u)d
so could you just arbitrarily say that the colour combination is,
RGB + (R)(G)(B) -> R(R) + (R)R
and thus color is conserved
Could somebody give me an example of a process that obeys everything besides color conservation so I know what I'm looking for?
Thanks.
As long as you conserve baryon number, color conservation takes care of itself. It's ust a matter of picking a consistent color assignment.
The observed particles are all color singulets (color-neutrality; this is different from the color confinement). This follows strictly from the SU(3) color gauge symmetry and the Gauss law constraint which enforces a color singulet condition. Colored states would transform non-trivially w.r.t. color gauge transformations.
So in order to observe color non-conservation one would first expect to find asymptotic colored states (which would violate color-neutrality individually). Second one would expect that the total color charge (of the individual states) does not add up to zero.
Thanks guys, that makes sense.
  • · Replies 46 ·
  • · Replies 35 ·
9K
