What are valid Preferred Frames?
  • Context: Graduate
  • Thread starter Thread starter Varon
    Frames
This discussion centers on the concept of preferred frames in physics, specifically within the contexts of Newtonian physics, special relativity, and general relativity. In Newtonian physics, Galilean inertial frames serve as preferred frames, while in special relativity, Lorentz inertial frames are considered preferred. However, general relativity lacks a universal preferred frame across all spacetime solutions, although local Lorentz inertial frames exist. The conversation also explores the implications of preferred frames on superluminal signaling and causality, questioning whether a field, such as the Higgs field, could serve as a valid preferred frame for instantaneous communication across vast distances.
  • Understanding of Galilean inertial frames in Newtonian physics
  • Familiarity with Lorentz inertial frames in special relativity
  • Knowledge of local Lorentz inertial frames in general relativity
  • Concept of causality in the context of superluminal signaling
  • Research the implications of superluminal signaling on causality in physics
  • Study the properties and applications of the Higgs field in modern physics
  • Explore the Friedmann-Robertson-Walker (FRW) solution in general relativity
  • Investigate the concept of symmetry in physical theories and its relation to preferred frames
Physicists, students of theoretical physics, and anyone interested in the foundational concepts of relativity and the implications of preferred frames on causality and superluminal communication.
Varon
Supposed, for sake of discussions. There are preferred frames.
Could a field (field in the context of higgs field, or other fields) be a preferred frame? What is a valid preferred frame where it is instantaneously to say communication between 100 billion light years distance and not violating causality (because in SR, anything superluminal without preferred frame can have frames where things go backward in time)?
A preferred frame is usually something which reveals an underlying symmetry of all solutions, or of the particular solution being studied.
In Newtonian physics, the preferred frames are Galilean inertial frames. All Galilean inertial frames are equally preferred, so within that class of frames, there are no preferred frames.
In special relativity, the preferred frames are Lorentz inertial frames. All Lorentz inertial frames are equally preferred, so within that class of frames, there are no preferred frames. (These preferred frames are due to the metric field, not the Higgs field.)
In general relativity, there are no preferred frames covering all of spacetime for all solutions. In all solutions, there are local preferred frames which the local Lorentz inertial frames. In some solutions, such as the FRW solution, there is a global coordinate system in which the spatial slices are isotropic and homogeneous, and this coordinate system is in that particular sense "preferred".
In all cases, whether a "preferred" or "non-preferred" frame is used (keep in mind that we have defined several different meanings of those words), the theory predicts the same result for any experiment.
I'm talking in the context of superluminal signalling. If one can transmit signal faster than light.. it can go backward in time in certain frames of reference. But not so if you have a preferred frame where you transmit the signal. No causality problem would result. Hence, could this hypthetical preferred frame for instantaneous signalling across the universe be a field (field in the sense of higgs field or other field)? What are valid preferred frames in this sense?
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 27 ·
