Does Half-Life Imply Radioactive Nuclides Never Reach Zero Activity?
  • Context: Undergrad
  • Thread starter Thread starter misogynisticfeminist
    Half-life
The discussion revolves around the concept of half-life in radioactive decay, specifically questioning whether radioactive nuclides ever reach zero activity over time. Participants explore the implications of half-life curves, the nature of radioactive decay, and the relationship between emitted radiation and mass loss.
  • One participant questions whether a sample of radioactive nuclides will eventually reach zero activity, noting that half-life curves are exponential and do not actually reach zero.
  • Another participant clarifies that half-life curves represent expectation values and probabilities, suggesting that while the number of particles may approach zero, it does not indicate that mass is lost in the same manner.
  • A different participant discusses the relationship between photon emission and mass, arguing that the emission of photons is accompanied by the emission of mass-bearing particles, thus affecting the overall mass of the substance.
  • One participant emphasizes that the mass of a substance decreases when it emits radiation, as energy is released in the form of photons, which contributes to mass loss.
  • Another participant asserts that the exponential decay graph is a prediction and does not imply that particles cannot become stable, suggesting that measurements are typically taken down to one particle rather than zero.
Participants express differing views on the implications of half-life and the relationship between emitted radiation and mass. There is no consensus on whether radioactive nuclides can reach zero activity, and the discussion remains unresolved.
Participants highlight the probabilistic nature of nuclear decay and the complexities involved in measuring mass and activity, indicating that assumptions about stability and decay processes may vary.
I've got a question regarding half-life. Half-life is the time taken when the mass or countrate emitted of a radioactive sample drops to half.
But if say, if a sample of 400 particular radioactive nuclides which go through radioactive decay. Won't the count rate reach 0 eventually, after decaying into a more stable state? (assuming no background count). Because if we plot a normal half-life curve, it would be exponential and would never reach 0 at all.
And if these particular nuclides emit gamma radiation, its mass wouldn't drop at all because the photons are massless, right?
Thanks.
A 'normal half-life curve' is probably a plot of the expectation value of the number of particles in a certain state or a fraction. Nuclear decay is a probabilistic in nature, so all we can give is an expectation value or some probablility density.
If you use a half-life curve on your example. After some time the curve has decayed to almost zero indicating the chance to find a aprticle after that duration is very small, so probably there will be no particle left.
Note that a half life curve does not indicate the mass left, just the number of particles of a certain type. Or the mass of the particles of that certain type.
Note also that if a substance emits radiation it's mass decreases, because a photon has energy, which also contributes to the mass of the object.
Thanks.
Hi miso,
IMO, whenever any nucleus emits a photonic particle, it is invariably coincidental to a simultaneous emission of a mass-bearing particle. E.g., a U-238 nucleus emits its most weakly attached alpha (of the 8 that it received when its parent, Pu-242, decayed), is accompanied by a ~45 KeV photon; the 4.190 MeV expulsion energy of the alpha (that is primarily controlled by electrostatic repulsion) is less than that which is available, 4.235MeV. Of course conservation of energy necessarily prevails. In order to cite details of photon emission that accompanies Beta (nucleus bound electron) emission, let me continue.
Let's talk about what happens to the new nucleus after U-238 loses its alpha. The reality is that it has become the nucleus of Thorium-234 that contains only 7 resident alphas; It is also quite nervous because the nucleus isn't happy because it has two too many neutrons. The only way to correct that problem is for a neutron to spontaneously emit an energetic electron. The Th-234 nucleus emits a beta thus becoming Protoactinium-234; the beta energy, depending on which one of 140 neutrons emits, is a spectrum of energies accompanied by a spectrum of photons. Typically, it might be suspected that high energy betas are accompanied by low energy photons; e.g., a 190 KeV beta coupled with a 29 KeV photon or a 100 KeV beta with a 91 KeV photon.
The Pa-234 decays in similar manner, to U-234; the betas are as much as 280 KeV and the gammas are as much as 1.68 MeV.
The U-234 is again an alpha emitter, and in similar manner repeats the alpha-beta-beta sequence until the nucleus has expelled all its available alphas thus becoming Pb-206. There are three other series that are represented by U-235, U-236 and U-233 as well as U-234 explained above. Thanks for your audience and your patience. Jim
Since matter is but a highly concentrated form of energy, the missing mass has actually been converted to energy, in your case, a gamma ray. In spontaneous emission, the electron loses mass, as decending to a lower energy and the lost mass was actually mass converted to energy, and released as a gamma ray.
:biggrin:
an exponential graph is just a prediction of what the mass would be after radioactive decay just bacause the graph does not reach zero doesn't mean that the particle won't become stable. it is just of those things that seem to happen, that is why we measure down to only one instead of zero.
day without sunshine......is well......like.....night
  • · Replies 20 ·
