Cauchy Integral Formula - Multiple Possible Solutions?
Leveret
Cauchy Integral Formula -- Multiple Possible Solutions?
I'm in the process of teaching myself some complex analysis, and I ran into the following conundrum:
Suppose one was given an integral,
\int_C \frac{1}{(z-a)(z-b)} \mathrm{d}z
where C is a closed curve with a and b in its interior, oriented counterclockwise.
f(a) = \frac{1}{2 \pi i} \int_C \frac{f(z)}{z-a} \mathrm{d}z
It seems to me that one could approach this one of two ways, and thereby obtain one of two different solutions. One possibility would be to say:
f(z) = \frac{2 \pi i}{z-b}
\int_C \frac{1}{(z-a)(z-b)} \mathrm{d}z = \frac{1}{2 \pi i} \int_C \frac{f(z)}{z-a} \mathrm{d}z = f(a) = \frac{2 \pi i}{a-b}
However, it seems equally valid to say:
f(z) = \frac{2 \pi i}{z-a}
\int_C \frac{1}{(z-a)(z-b)} \mathrm{d}z = \frac{1}{2 \pi i} \int_C \frac{f(z)}{z-b} \mathrm{d}z = f(b) = \frac{2 \pi i}{b-a}
which differs from the former solution by a factor of -1. Is this by design, or am I missing something important about the Cauchy integral formula (which is completely plausible)?
The Cauchy formula says that if f is homomorphic in the interior of C then your first result would hold: that is, the integral of f(z)/(z-a) would give 2*pi*f(a). However, f(z) = 1/(z-b) is not holomorphic (it has a pole at z = b in the interior of C) so the result need not hold.
RGV
Cauchy's Integral Formula requires f(z) to be analytic inside and on the boundary of the contour.
When there are multiple singularities within the contour, we use the Residue Theorem.
Gotcha, thanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
