Stopping Distance & Coefficient of Friction for a Decelerating Car
  • Thread starter Thread starter Mivz18
    Car
The discussion revolves around a physics problem involving a car's stopping distance, acceleration, and the coefficient of friction on an incline. The original poster is attempting to determine the maximum angle at which the car can park on a hill, given the static coefficient of friction derived from previous parts of the problem.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the forces acting on the car on an incline, including normal force, static friction, and gravitational components. There are attempts to set up equations based on these forces to solve for the angle of the incline.
Some participants have provided guidance on analyzing the forces and setting up equations based on equilibrium conditions. There is ongoing exploration of the relationships between the forces and the angle, with no explicit consensus reached on the next steps.
Participants are working under the constraints of the problem's requirements, including the use of the static coefficient of friction and the need to analyze forces in both parallel and perpendicular directions to the incline.
Mivz18
I'm having trouble with the third part to this question:
On a level road with its brakes on, the shortest distance in which a car traveling with 93 km/hr can stop is 91 m. This shortest distance occurs when the driver uses anti-lock brakes which means that that the car brakes without skidding.
The first part asks what the magnitude of the acceleration of the car is and I found that to be the absolute value of 3.67.
The second part asks what the coefficient between the tires and the pavement is and I found that to be 0.374 .
The third part then asks How steep a hill can the car park on, with the angle to the horizontal. I have no clue how to go about this. The only hint or help given on the online program is "Since the car stopped without skidding, the coefficient of friction you found in part (b) is actually the static coefficient of friction, which is the proper coefficient of friction for this part as well. "
How do I go about figuring this out with the information I have?
Can you draw an FBD for a block (car) resting on an inclined plane?
ok, I get three forces. I don't know how to demonstrate that here, but there is a normal force, static friction going up and mg force angled down in which you find by means of vector addition. So where would I go from there?
Well, if you say that the angle of the slope is [tex]\theta[/tex] then you should be able to calculate the component of gravity that acts along the slope which must be counteracted by, and the component which acts perpendicular to the slope which must be counteracted by the normal force. If you recall that [tex]F_{friction}=\mu_s N[/tex] you should be able to set up an equation with [tex]\theta[/tex] as the unknown.
I'm still kind of lost on this problem. When I try to look for Fnet, I get :
Fnet = W + N + Fs or
Fnet = mg + mgy + (mu)mg or
Fnet = mg + mgcosx + (mu)mg
Am I doing this correct so far??
You are correct that there are three forces acting on the car:
gravity, acting down
friction, acting up the incline
normal force, acting perpendicular to the incline
Now analyze the components of those forces parallel and perpendicular to the plane. (Since the car isn't moving, it's in equilibrium: the net force is zero in any direction.) Get two equations, one for each of those directions. Combine them to solve for the angle of the incline.
I'm in a bind. I figured out the Fnet for each direction:
Fnet of x = 0 = N - mg of y = mg - mgcosx
Fnet of y = 0 = Fs - mg of x = (mu)mg - mgsinx
Then, when I try to solve for theta (x), I get mg(1 - cosx) = mg( (mu) - sinx)
Simplified, 1-cosx = (mu) - sinx or 0.626 = cosx - sinx
Where do I go from here? Is this a trig equation trick that I'm overlooking? Because it isn't a half angle or anything like that? Or am I going in the wrong direction with this?
Your force equations have an error: the normal force is not mg. I'll rewrite them:
(1) [itex]N = mg cos\theta[/itex]
(2) [itex]\mu N = mg sin\theta[/itex]
Now see if you can solve for [itex]\theta[/itex].
  • · Replies 19 ·
22K
  • · Replies 16 ·
