Interpretiing the Dolbeault operators
  • Context: Graduate
  • Thread starter Thread starter lavinia
    Operators
The Dolbeault operators provide a framework for interpreting the differential of a function as a map on tangent spaces, clarifying the interaction between this map and complex multiplication. A function is holomorphic if the condition \(\frac{d}{d\bar{z}}f(z)=0\) holds, indicating that the Jacobian commutes with multiplication by \(i\). For non-holomorphic maps, the Jacobian can be decomposed into components that either commute or anticommute with complex multiplication. This interpretation is particularly relevant in the context of conformal atlases on Riemann surfaces, where operations can resemble rotations in isothermal coordinates.
  • Understanding of Dolbeault operators
  • Familiarity with complex analysis and holomorphic functions
  • Knowledge of tangent spaces and Jacobians
  • Concept of Riemann surfaces and isothermal coordinates
  • Study the properties and applications of Dolbeault operators in complex geometry
  • Learn about the relationship between holomorphic functions and their Jacobians
  • Explore the concept of isothermal coordinates in Riemann surfaces
  • Investigate the implications of complex multiplication on differential forms
Mathematicians, particularly those specializing in complex geometry, differential geometry, and anyone studying the properties of Riemann surfaces and holomorphic functions.
lavinia
The differential of a function may me interpreted a the the dual of its gradient.
What is the interpretation of the Dolbeault operators?
Hmm, I'd prefer to interpret the differential of a function as a map on tangent spaces. Then the Dolbeault operators further clarify the interaction between the map and complex multiplication. Recall that a map from C to C is holomorphic if and only if [itex]\frac{d}{d\bar{z}}f(z)=0[/itex]. Phrased another way, the Jacobian of the map commutes with multiplication by i. If we then look at a map from C to C which is not necessarily holomorphic, we can decompose its Jacobian into components which commute/anticommute with complex multiplication.
Of course, one may attempt to extend this to your case, by defining holomorphic gradients and the like, but IMO it's clearer this way.
Thanks. I got the thought - maybe wrong - that in a particular conformal atlas of charts on a Riemann surface - the operation adx + bdy -> -bdx + a dy is well defined. It is something like a rotation by 90 degrees but there is no Riemannain metric. I guess it would be a rotation in isothermal coordinates.
  • · Replies 59 ·
  • · Replies 29 ·
