New Reply
Stupid question - is it possible to use up all the oxygen in your room?
Share Thread Thread Tools
May25-11, 11:02 AM   #1
I have a stupid question to ask you all.
Let's just say that you shut your door, and then shut all your windows so there isn't any ventilation and stayed in your room for several days. Could you end up breathing until you've reduced the oxygen to dangerous levels?
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Non-wetting fabric drains sweat
>> Protein study suggests drug side effects are inevitable
>> RNA capable of catalyzing electron transfer on early earth with iron's help, study says
May25-11, 05:10 PM   #2
If it's completely sealed and there's no other source of oxygen, then sure.
May26-11, 11:29 AM   #3
And how long would it take to run out of oxygen?
I often wonder if there's a tiny little gap of say, 1 square cm to the outside world, would you rate of oxygen consumption beat the inflow of oxygen?
May26-11, 12:14 PM   #4
Stupid question, you bet you!
Not so stupid answer though:
Go study partial differential equations, and determine for yourself the air flow given the size of the hole, temperature, etc.... after factoring in all these variables then determine how big the hole has to be. Btw, in a room built out of wood, the oxygen would still get through, so this needs to be a room of plastic; why don't you tell us how big the whole has to be to substain life? Go now, study :p
May26-11, 07:14 PM   #5
Mentor
The short answer is that you'd need a ridiculously well sealed building to create such a problem. I once ran across a building that used to be a FEMA office and it was designed pretty air tight, so it required continuous ventilation to keep the air quality acceptable.
Note, though, that you can't "use up all the oxygen" in a room: It isn't lack of oxygen that would kill you, it is too much CO2.
May28-11, 09:57 AM   #6
If you use completely compartmentalized room then yes. But When the O2 level decrease to certain level the partial pressure of O2 is so low that haemoglobin would not combine with oxygen, then you are just going to die before it is completely used up. So It's never going to "use up" literally.
New Reply
Thread Tools
Similar Threads for: Stupid question - is it possible to use up all the oxygen in your room?
Thread Forum Replies
Stupid me with a stupid question about Wireless internet Computers 1
No such thing as a stupid question, just stupid.. Special & General Relativity 5
Boiling water - oscillation; when oxygen needs more room Introductory Physics Homework 5
Stupid question looking for stupid answer General Astronomy 6
a stupid question by a stupid person General Physics 3
