| New Reply |
On "why massless particles move at the speed of light" |
Share Thread |
| May29-11, 08:29 AM | #1 |
It has come up a few times whether you can derive that massless particles must go the speed of light, strictly using SR. Bcrowell proposed a way that some argued against. I have a different tack for consideration.
I recently derived that, for any particle with E0 (rest energy) > 0, the following is true: (1 - v^2/c^2) = 1 - KE / (KE + E0) From this you can say: 1) limit as E0 -> 0 leads to v=c 2) If there is to be such a thing as a particle with E0=0 and nonzero KE, and if it should be consistent with the SR, then this relation directly requires that v=c. |
| May29-11, 08:44 PM | #2 |
sqrt(1 - v^2/c^2) = 1 - KE / (KE + E0) |
| Jun2-11, 07:58 AM | #3 |
The rest mass of a particle is defined to be the norm of its momentum 4-vector. There are only two kinds of vectors that have zero norm: null vectors and the zero vector. So a particle which is massless either travels at the speed of light or carries no energy and momentum at all.
| Jun2-11, 08:11 AM | #4 |
| Jun2-11, 12:26 PM | #5 |
| Jun2-11, 01:40 PM | #6 |
Recognitions:
given the Lagrangian L(x, v) where v = dx/dt define [tex] p = \frac{\partial L}{\partial v} [/tex] This serves as an adequate definition of momentum. A Lagrangian is defined as "good" if the equations of motion [tex] \frac{dp}{dt} = \frac{\partial L}{\partial x} [/tex] are correct, i.e. match observation. And E would be given by E = p*v - L (more generally the sum over i of p_i *v_i - L when you have more than one dimension) |
| Jun2-11, 02:13 PM | #7 |
The point I was trying to make is that postulating the existence of rest/invariant mass, assuming it nonzero and the form of the Lagrangian of a free particle of rest mass m_0 leads to P^2 = m^2. Point: P^2 = m^2 is a consequence, not an assumption/definition/axiom.
Assume it in reverse, then what are the Lagrangian & Hamiltonian formulations of the theory with P^2 =0, thus with invariant mass = 0 ? |
| Jun2-11, 03:11 PM | #8 |
E^2=P^2 c^2 So now newbie asks, isn't P = m gamma v = 0 if m=0? Contradiction (since E assumed nonzero)? So now the problem has been transposed to showing why P=E/c implies speed is c. [Edit: Of course, one way to do this is to write the general: P = Ev/c^2 ; then the requirement that P = E/c implies v=c. But with this addition I don't see much superiority to this approach. ] |
| New Reply |
Similar discussions for: On "why massless particles move at the speed of light"
| QED: the strange theory of light and matter. " Light is made of particles " ? | Quantum Physics | 20 | ||
| "Using light to see the world requires speed of light to be maximum?" | Special & General Relativity | 23 | ||
| control creation time of light "particles" | High Energy, Nuclear, Particle Physics | 6 | ||
| Why cant "forces" travel faster than light speed? | Special & General Relativity | 8 | ||
| another B.Forums blooper: "It grows at the speed of light" | General Astronomy | 6 | ||
