Simultaneous Causation and Entanglement
  • Context: Graduate
  • Thread starter Thread starter Atype*
    Entanglement
The discussion centers around the concept of "simultaneous causation" in the context of quantum entanglement and whether entangled particles exhibit causative relationships or merely correlations. Participants explore philosophical implications and the nature of measurements in quantum mechanics.
  • Some participants propose that entanglement implies correlation rather than causation, arguing that measuring one particle does not transmit a signal to the other particle.
  • It is noted that the lack of detected signals and the requirement for faster-than-light communication suggest that the relationship is not causal.
  • One participant compares the situation to classical conservation of angular momentum, highlighting differences in the definiteness of values before measurement in classical versus quantum cases.
  • Another participant mentions a counterargument that the measurement itself could be considered a cause of the effect observed in the other particle, suggesting a simultaneous effect beyond the light cone.
  • There is a sentiment expressed that the discussion may be more about semantics than substantive differences in understanding causation and correlation.
Participants generally disagree on whether the relationship between entangled particles is one of causation or merely correlation, with multiple competing views remaining unresolved.
Participants express uncertainty regarding the definitions of causation and correlation in the context of quantum mechanics, and the discussion reflects differing interpretations of measurement effects.
Atype*
I have seen the concept of "simultaneous causation" described in philosophy, the notion that A can cause B at a simultaneous time. This sounded suspect to me and so I asked for a reference to provide evidence that this is a real phenomenon , this is what i was provided with:
http://eve.physics.ox.ac.uk/NewWeb/Research/communication/communication.html
"These operations, although performed only on one particle, affect the joint (entangled) quantum state of the two particles. This cannot be verified by measurements on the two particles separately. But by measuring both of them jointly, using the quantum gate M, Bob can determine which of the four operations Alice performed, and so receive one of the four messages. Thus the technique effectively doubles the peak capacity of an information channel."
However i have also been told that entanglement implies a correlation but not causation. Can anyone clear this is up?
Is this an example of Simultaneous Causation or not? If not ,why not? Is this a real verified in the real world phenomenon or not?
As far as we know right now, it is simply a correlation, not a causation. A measurement of one doesn't cause a signal to be transmitted to tell the other particle what it has to do. We know this because (i) the signal will have to be extremely fast (many times faster than c), and (ii) no signal has been detected.
So it is more like a correlation. This is no different than the classical case of conservation of angular momentum, let's say. If you measure the angular momentum of one, you immediately know the angular momentum of the other. The major difference between the two is that the classical case, these particles have definite momentum values even before measurement, whereas in the quantum case, superposition indicates that the values are not set before a measurement.
Zz.
Zz.
Hi Zapper Z thanks you for that, IM on a philosophical forum and asked the person claiming the opposite to come to this forum to discuss their views but they refused. So I have posted below their response:
"Then it's not just a correlation since the effect is a result of the measurement, and the effect is simultaneous (i.e., beyond the light cone of the observer) with the measurement. The measurement is a cause of the effect -- not the cause of a ftl
"signal."
If you or anyone else could respond it would be very much appreciated.
This is more of a game of semantics. I do not waste my time with such thing.
The measurement is the case of the "effect" that we know the spin state of one particle. But knowing that doesn't CAUSE the spin state of the OTHER particle. So what I stated is that there is no cause-and-effect mechanism for the knowledge of the spin state of the OTHER particle.
Doing this via an intermediary is frustrating. If they do not wish to be here, then you are on your own. Carrying a discussion with someone in another forum is not my idea of a productive time use. So this will be my last response to this issue.
Zz.
I know what you mean, its a shame they won't come on here to defend their views because i find this a fascinating topic but so be it. Thanks very much for your replies.
  • · Replies 58 ·
  • · Replies 41 ·
  • · Replies 71 ·
9K
