Classical Mechanics, constraint motion problem
The discussion revolves around a classical mechanics problem involving a particle of mass m moving under a uniform gravitational field along a rod that rotates in a vertical plane with a constant angular velocity. Participants are tasked with writing the motion equations for the particle, calculating the constraint force, and discussing energy conservation within the system.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the use of Lagrangian mechanics and question how to modify the Lagrange equations for non-conservative systems. There is discussion about the nature of energy conservation in the context of the problem, with some expressing uncertainty about the role of constraints and the application of Lagrange multipliers.
Participants are actively engaging with the problem, sharing their attempts and reasoning. Some have provided insights into the use of Lagrange multipliers and the implications of the constraint on energy conservation. There is a recognition of the complexity of the problem, with various interpretations and approaches being explored.
There are indications of missing information regarding the motion of the rod and the nature of the forces involved. Participants are also navigating the constraints imposed by the problem setup, particularly in relation to the conservation of energy and the behavior of the system over time.
fluidistic
A particle of mass m moves under a uniform gravitational field along a rod which moves in a vertical plane with a constant angular velocity [itex]\vec \Omega[/itex]. Write down the motion equations of the particle and calculate the constraint force. Is the energy conserved? Discuss.
Lagrangian and... not really sure, maybe some modified Lagrange equation?
I have a very strong feeling the energy isn't conserved. I understand how the particle will move and without someone to move the rod the motion will eventually end so there's some dissipation of energy I believe. I'm not sure the Lagrangian is still T-V.
Anyway, assuming it's still T-V, I chose polar coordinates r, theta to describe the position of the particle. My reference frame is in the middle of the rod (I assume it's "fixed").
[itex]T=\frac{m}{2}r^2 \dot \theta ^2[/itex] and [itex]V=mgr \sin \theta[/itex].
Now is my bigger problem. I don't know AT ALL how to modify the Lagrange equation!
I mean, I know that [itex]\frac{\partial L}{\partial q_i}- \frac{d}{dt} \left ( \frac{\partial L}{\partial \dot q_i} \right ) \neq 0[/itex], unlike in conservative systems.
I guess I have to use some Lagrange multipliers but I'm not even sure. I'm stuck here. How to calculate the constraint force? I know it's the force the rod exert on the particle so it would be the normal force, namely [itex]mg \cos \theta[/itex] but I'd have to solve for [itex]\theta (t)[/itex]. Hmm... wait it seems rather easy. Since [itex]\dot \theta = \Omega[/itex], I have that [itex]\theta ( t)= \Omega t + \theta _0[/itex].
I guess r(t) would be much harder to find, but do I need it?
Also, how do I prove that the energy is not conserved? Maybe deriving the Lagrangian with respect to time and if it's not worth 0 it means the Lagrangian is not constant and thus (I believe the implication is true), E isn't constant. Is this a good approach? Am I missing stuff?
Good intuition!
Actually, the motion wouldn't end in a perfect frictionless world. However, there's no way the rod can maintain a constant rotational speed all on its own, because the particle keeps on applying a force to it and accelerating it in this direction or that.
Actually, you don't have to modify the Lagrange equation at all. A non-conservative case is where an explicit external force (like friction) is introduced into the system. Here, you don't have to deal with an external force; you just need to deal with an internal constraint.
Yes, Lagrange multipliers is the right approach to take. You've already figured out what your constraint should be: [itex]\theta ( t)= \Omega t + \theta _0[/itex]. The amazing thing about Lagrange multipliers is that the value of the multiplier gives you the constraint force. Here, your constraint forces the particle to remain on the rod, so the multiplier gives you the force that the rod exerts on the particle to make it stay on the rod.
Yes, that's the right approach. Noether's theorem says that if the Lagrangian is invariant under time translation, energy is conserved. Here, our constraint explicitly depends on time, so the Lagrangian is obviously not invariant.
Thanks for your reply, that's very helpful/encouraging.
I've been looking into Goldstein's book (1st edition) about Lagrange multipliers. I don't think I understand well, but here's what I've done:
The constraint equation is [itex]\theta - \Omega t - \theta _0 =0[/itex].
[itex]a_{\theta}=1[/itex].
Thus [itex]m(2 \dot r r \dot \theta + r^2 \ddot \theta )+mg r \cos \theta - \lambda=0[/itex].
I notice that [itex]\ddot \theta =0[/itex].
I also have that [itex]r=\frac{g \sin \theta}{\Omega ^2}, \dot r = \frac{g \Omega \cos (\theta )\Omega ^2}{\Omega ^4}=\frac{g \cos \theta }{\Omega }[/itex].
This gives me the equation [itex]\frac{mg^2 \sin \theta \cos \theta}{\Omega ^2 } \left ( \frac{2}{\Omega } +1 \right ) - \lambda=0[/itex].
I'm not sure I'm doing things right. I know I'm not finished but I don't know what to do next.
Thus [itex]m(2 \dot r r \dot \theta + r^2 \ddot \theta )+mg r \cos \theta - \lambda=0[/itex]. I notice that [itex]\ddot \theta =0[/itex].
Yup, that's right. Note that [itex]\lambda = 2m \dot r r \dot \theta+mg r \cos \theta[/itex]
That's pretty much what I got, except I have an extra factor of 1/2 for r.
Yup, you're definitely doing things right, and I think you are finished. You know how theta behaves--it's just wt+theta_0. You've already found the equation of motion for r. The constraint force is just lambda. Note that lambda is the sum of gravity and the Coriolis force, which is exactly what you'd expect with Newtonian mechanics.
Thank you very much for everything! Sorry for having took so much time to reply, I was busy with another course.
My Lagrangian is [itex]L=\frac{mr^2 \dot \theta ^2 }{2}-mgr \sin \theta[/itex]. When I do [itex]\frac{\partial L }{\partial r }[/itex] and I isolate r, I reach [itex]r = \frac{g \sin \theta }{\Omega ^2}[/itex]. May I know how you got your extra 1/2 factor?
The Lagrangian should be [itex]L=\frac{mr^2 \dot \theta ^2 }{2}+\frac{m\dot r ^2}{2}-mgr \sin \theta[/itex]. You have to account for motion along the radial direction.
Ah I see, I understand.
Well it's a bit too late for me now (past 2 am) so I'm going to try tomorrow. It doesn't seem as easy as I thought to get r though. Lagrange's equation gives [itex]\ddot r - r \dot \theta ^2 +g \sin \theta =0[/itex]. I'll work on it and post here tomorrow.
Yeah, that's why I was surprised that you got the answer without showing any work, considering that the rest of the solution was very detailed.
You could go through the motions of solving this second-order linear inhomogenous differential equation, or you could take a random guess and hope that it works. It turns that this "random guess" approach is more useful, especially since I already gave away the answer. :biggrin:
Sorry for being so late to thank you, but thanks anyway.
I'm going to take the second approach for now. :) If I have some problems I'll post here.
