Why Does AgCl Precipitate While KNO3 Remains in Solution?
  • Thread starter Thread starter mburt
    Curious
The discussion centers on the precipitation reaction between silver nitrate (AgNO3) and potassium chloride (KCl), specifically exploring why silver chloride (AgCl) precipitates while potassium nitrate (KNO3) remains in solution. The scope includes theoretical aspects of solubility and precipitation reactions.
  • Homework-related
  • One participant describes the precipitation of AgCl as a solid and questions why K+ and NO3- do not form KNO3(s) as a precipitate.
  • Another participant mentions "rules of solubility" as a way to predict the formation of precipitates based on the ions involved, suggesting that these rules are complex and influenced by molecular geometry.
  • A different participant elaborates on the factors influencing solubility, indicating that the stability of solids versus solutions is a result of ionic interactions and entropy considerations.
  • One participant references equilibrium constants, noting that the low value for AgCl indicates it is less soluble compared to KNO3, which has a high solubility, thus explaining the observed behavior in the reaction.
Participants express varying levels of understanding regarding the solubility rules and the underlying thermodynamic principles. There is no consensus on a singular explanation for the observed phenomena, as different aspects of solubility and stability are discussed.
Participants reference equilibrium constants and solubility rules without providing specific definitions or values, leaving some assumptions and dependencies on these concepts unresolved.
mburt
An example of a precipitation reaction: Aqueous silver nitrate (AgNO3) is added to a solution containing potassium chloride (KCl) and the precipitation of a white solid, silver chloride is observed. (Zumdahl, 2005)
The silver chloride (AgCl) has formed a solid, which is observed as a precipitate.
This reaction can be written emphasizing the dissociated ions in a combined solution. This is known as the ionic equation.
Ag+ (aq) + NO3− (aq) + K+ (aq) + Cl− (aq) → AgCl (s) + K+ (aq) + NO3− (aq)
none.
Okay, so I know that the AgCl(s) precipitate forms but how come the K+ and the NO3- do not combine to form KNO3(s)? And how would I know that KNO3(s) is not the formed precipitate?
You know because of the "rules of solubility". They give you a general idea of how likely something is to form a precipitate, depending on it's ions. It's a little more complex than that, has to do with molecular geometry somewhat, but the rules of solubility are how you can predict that you will get Silver Nitrate from that etc.
Rules of solubility are kind of a rule of thumb, used to predict what will happen. Thermodynamics behind is sometimes rather complicated, but it is always result of a difference of stability - sometimes solid salt is more stable, sometimes its solution is more stable. Solids are stabilized by the interactions between ions (or molecules) they are composed of, solutions are stabilized by the increase of entropy and interactions between ions and water molecule dipoles. It is combination of these factors that yields final effect - precipitate, or lack of one.
If you're familiar with equilibrium constants: the value for AgCl is <10-9, while the value for KNO3 is >1. If follows that the first will barely dissolve (i.e., will precipitate when given a chance), while the second will readily dissolve. You can look up tabulated values for essentially any salt.
16K
10K
