Phase space in particle physics: what is it?
The discussion centers around the concept of "phase space" in the context of particle physics, particularly in relation to particle decay processes. Participants explore its definition, implications for decay rates, and its relationship to energy and momentum conservation.
  • One participant notes that the term "phase space" is introduced in a textbook without a clear definition, prompting a request for clarification.
  • Another participant suggests that phase space is essentially related to energy-momentum conservation, indicating that the rest mass of the decay products must be compared to that of the initial particle.
  • A different viewpoint describes phase space as the amount of momentum available to the decaying particle, explaining that limited phase space occurs when the rest mass of the products is close to that of the initial particle.
  • Another participant elaborates that phase space for a system consists of possible momentum and energy points, providing an example of a decay process and describing the geometric representation of phase space.
Participants express varying interpretations of phase space, with no consensus on a single definition or understanding. Multiple competing views remain regarding its implications and mathematical representation.
Some participants reference specific decay processes and the relationship between mass and momentum, but there are unresolved details regarding the explicit expressions for phase space as mentioned in the textbook.
tiger_striped_cat
This should be an easy general question to someone out there. My "quarks and Leptons" book by Halzen and Martin introduces the term "phase space" 50 pages before the index reference, and never seems to define it.
The decay
[tex]\psi(s\overline{s}) \longrightarrow K(q\overline{s}) + \overline{K}(\overline{q}s)[/tex]
with q= u,d is inhibited by lack of phase space while [tex]\phi \longrightarrow \pi\pi\pi[/tex] has plenty of phase space but requires annihilation of the [tex]s\overline{s}[/tex] pair.
What is phase space in this context?
Thanks
Just a fancy term for energy-momentum conservation. In a nutshell, either the rest mass of the products is larger than the rest mass of the initial particle, or the difference is extremely small. Most likely the formerl.
Thanks
Roughly speaking, it's a jargon term for the amount of momentum available to the decaying particle. If the sum of the rest mass of the product particles is very close to the rest mass of the initial particle, one says that there is little phase space available, meaning that that the produced particles are created with almost no three-momenta (in the rest frame of the decaying particle). However, if the mass of the produced particles is much smaller than the mass of the decaying particle, there's plenty of momentum to share among the produced particles and this enhanced the decay rate.
By the way, H&M *do* define the explicit expressions for phase space in the case of a decaying particle. Unfortunately, I don't have it with me but I'll give you the equation number later if you want.
Pat
Phase space for a system is the set of possible momentum/energy points for which momentum and energy are conserved. If, for example, A -> B + C, then in A's center of momentum frame, pB + pC = 0 (3D vector equation), and eB+eC = mA. In this case, the available phase space is a spherical surface whose radius depends on the masses.
Also, sometimes people will refer to integration over 3- or 4- momentum space as integration over phase space.
Regards,
Reilly Atkinson
  • · Replies 0 ·
  • · Replies 87 ·
9K
