At what point on the x-axis is the field greatest?
  • Thread starter Thread starter mugzieee
    Field Point
The electric field E generated by a uniformly charged circular ring of radius r, centered at the origin, is defined as E = kx/(x^2 + r^2)^(3/2). The analysis reveals that the electric field is greatest at x = 0 and least inside the ring, where E equals zero. The first derivative, E' = k(-2x^2 + r^2 - 3xr)/(x^2 + r^2)^(5/2), identifies the critical point at x = 0. The second derivative test confirms that this critical point is a minimum, indicating that the electric field outside the ring is greater than zero.
  • Understanding of electric fields and charge distribution
  • Knowledge of calculus, specifically derivatives and critical points
  • Familiarity with the concept of spherical conductors and their electric field properties
  • Basic grasp of the mathematical representation of electric fields
  • Study the implications of electric field behavior in charged conductors
  • Learn about the method of second derivatives for classifying critical points
  • Explore the concept of electric field strength in different geometries, such as spherical and cylindrical
  • Investigate the applications of electric fields in real-world scenarios, such as capacitors and sensors
Students and professionals in physics, electrical engineering, and applied mathematics who are analyzing electric fields and their properties in charged systems.
mugzieee
a circular ring of wire radius r lies in a plane perpendicular to the x-axis and is centered at the origin. The ring has a positive electric charge spread uniformly over it. The electric field in the x-direction, E, at the point x on the x-axis is given by E= kx/(x^2 + r^2)^(3/2) for k>0. At what point on the x-axis is the field greatest? Least?
After taking the first derivative i ended up with:
i know after the derivative I am supposed to find the critical points then classify them and find the global min and global max, but for critical points i end up with only a zero, what does it look like is wrong here?
The Important thing to know is that , The charge on a conductor ( in this case the circular ring ) resides on its outer surface. Therefore, electric field E inside the ring is zero.
2nd, For a point on the charged spherical conductor or outside it, the charge may be assumed to be concentrated at its centre.
Based on this least E which is zero, inside the ring.
The greatest is outside, the ring.
I hope this helps.
I don't know if you really need to take the derivative in this question. This seems more like a conceptual problem.
The critical point found from taking the derivative is correct, as it is the only point where the derivative is equal to zero. However, this does not necessarily mean it is the only critical point. To determine if it is a maximum or minimum, you need to take the second derivative and evaluate it at the critical point. If the second derivative is positive, then the critical point is a minimum, and if it is negative, then it is a maximum. In this case, taking the second derivative would result in a positive value, indicating that the critical point is a minimum. Therefore, the point on the x-axis where the electric field is greatest is at x = 0, and the point where it is least is at the point where the electric field is equal to zero, which can be found by setting the original equation equal to zero and solving for x.
