Calculating Nd:YAG Laser pulse energy
  • Context: Undergrad
  • Thread starter Thread starter bakelas83
    Energy Laser Pulse
The discussion revolves around calculating the pulse energy of a pulsed Nd:YAG laser used for welding applications. Participants explore the relationship between pulse energy, pulse duration, repetition rate, and mean power, as well as the implications of adjusting electric current on laser power.
  • One participant inquires about calculating pulse energy given the laser pulse duration, frequency, and mean power.
  • Another participant suggests that pulse energy can be calculated using the formula: (mean power) / (repetition rate), explaining the relationship between power and energy.
  • A participant questions whether pulse duration affects pulse power, seeking clarification on the relationship between these variables.
  • It is noted that while pulse duration affects pulse power, it does not affect pulse energy, which was the original inquiry.
  • A further question is raised about determining laser power based on electric current settings, specifically asking how to relate current to laser power.
  • Another participant responds that it is not possible to calculate laser power solely from current due to varying efficiencies of different lasers, suggesting measurement as a solution.
Participants generally agree on the formula for calculating pulse energy, but there is a lack of consensus regarding the relationship between pulse duration and pulse power, as well as the method for determining laser power from electric current.
There are limitations regarding the assumptions about laser efficiency and the need for empirical measurement to establish relationships between current and power.
bakelas83
I have a question, I used pulsed Nd:YAG laser to weld a steel part but I didn’t measure the pulse energy during the experiment. I was wondering if there is a way to calculate it somehow?
I have laser pulse duration, frequency (repetition rate), and laser (mean) power.
Thanks
Science news on Phys.org
Welcome to Physics Forums :smile:
The pulse energy is (mean) power x pulse period, or equivalently
(mean power) / (rep. rate)​
This makes sense if you think about the units, and the fact that power is energy-per-second:
[tex]\frac{( \text{energy/second)}}{ \text{(pulses/second)}} = \text{(energy/pulse)}[/tex]
Yes. You are right. But doesn’t the pulse duration have an effect on the pulse power?
I mean does the pulse power change directly with change in pulse duration or not?
Thanks
Yes, it affects the pulse power. But it does not affect the pulse energy, which was your original question.
Pulse power = (pulse energy) / (pulse duration)​
Thanks. I have one other question. The laser machine I was working with had an adjustment option for I (electric current in terms of mA) instead of laser power. How can I find laser power with this information?:confused:
There is no way to calculate laser power just from knowing the current. Different lasers have different efficiencies for converting the electrical energy into laser beam energy.
You would have to measure the laser power at the current setting you used. Or, measure the laser power at several different currents and make a graph (should be a straight line, if this YAG laser emits in the infrared), from which you can get the laser power at any current.
  • · Replies 29 ·
10K
