When does LiAlH4 act as a base and when does it act as a nucleophile?
  • Thread starter Thread starter MechRocket
    Act Base
The discussion centers on the dual behavior of lithium aluminum hydride (LiAlH4) as both a base and a nucleophile, particularly in reactions involving carboxylic acids and carbonyl compounds. Participants explore the conditions under which LiAlH4 acts in these roles, examining the mechanisms and factors influencing its reactivity.
  • Some participants question why LiAlH4 is predominantly represented as a nucleophile attacking the carbonyl function rather than acting as a base to deprotonate the hydroxyl group of carboxylic acids.
  • There are inquiries about the ability of LiAlH4 to deprotonate alpha carbons of carbonyl compounds that are relatively acidic.
  • One participant suggests that the negative charge in AlH4 is primarily on the aluminum, which may limit its ability to act as a base due to low charge density on the hydride ions.
  • Another participant notes that while proton exchange is generally faster than nucleophilic attack, the coordination of aluminum in AlH4 may prevent it from acting as a proton acceptor in certain contexts.
  • There is a mention of "dihydrogen bonds" formed by hydrides, although it is suggested that this interaction is not significant for AlH4 due to the charge distribution on the aluminum center.
Participants express differing views on the reactivity of LiAlH4, with some emphasizing its nucleophilic behavior while others highlight its potential as a base. The discussion remains unresolved regarding the conditions that favor one behavior over the other.
Participants acknowledge that the charge distribution and coordination of aluminum in AlH4 may influence its reactivity, but the implications of these factors are not fully explored or agreed upon.
MechRocket
When you throw in LiAlH4 with a carboxylic acid, you always see the reaction being written out as the Hydride ion attacking the carbonyl function.
But why can't it just de-protonate the OH?
Also, can't LAH also deprotonate alpha carbons of carbonyl functions that are pretty acidic?
Why do we always see it acting as a nucleophile rather than a base when we throw it in with carbonyls? De-protonation is much faster than nucleophilic attack isn't it?
Chemistry news on Phys.org
Where have you seen LAH acting as a nucleophile for acids?
the proper charge in AlH4 (-) is on the aluminium not the hydrogen. Essentially the negative charge density on the hydrogen is too low for them to act as a base. This isn't to say it won't, but that the nucleophilicity of the aluminium is high enough that the acid-base reaction is of low importance.
This is the reason we use reagents like Aluminium hydride and Borohydride: because they're allow a sort of nucleophilic addition of hydride.
In addition to the other comments, I would add that you are right that proton exchange is usually (much) faster than other chemical processes, in cases where there is a clear proton donor and acceptor. However, in this case, the Al in the AlH4- is coordinatively saturated ... in other words, there is no place for another (5th) proton to coordinate, so although there may be proton donors around, there really isn't a proton acceptor. On the other hand, hydrides can form fairly strong "dihydrogen bonds" .. these are like normal H-bonds, except the partially negatively charged hydride interacts with the partial positively charged proton. I suspect the reason this doesn't happen to a significant extent for AlH4- is (as noted by a previous poster), the negative charge resides primarily on the aluminum center.
