The discussion revolves around methods for calculating the mass of a black hole, specifically using examples like Cygnus X-1. Participants explore various approaches, equations, and concepts related to black hole mass determination, including both classical mechanics and general relativity considerations.
- Exploratory
- Technical explanation
- Mathematical reasoning
- Debate/contested
- Jack expresses uncertainty about how to calculate the mass of a black hole and asks for guidance on relevant examples and equations.
- One participant suggests using Doppler shift data to determine the speed of a star orbiting the black hole, along with its orbital radius, to calculate the black hole's mass using Newton's gravitational formula.
- Another participant shares a calculation of the Schwarzschild radius based on a mass of 1.2 x 10^31 kg, arriving at 17.7 km, but notes that their approach does not consider relativity.
- A subsequent reply confirms the Schwarzschild radius calculation as approximately 17.8 km but emphasizes that the method used is based on Newtonian mechanics, which may not be fully accurate according to general relativity.
- There is a discussion about the validity of using Newtonian mechanics for such calculations, with one participant arguing that it can yield correct results under certain conditions.
- Another participant introduces the Magorrian relation as a method for calculating the mass of a central black hole in a galaxy, referencing a correlation found in a specific paper.
- One participant claims to have derived the formula for the Schwarzschild radius using only Newtonian mechanics, asserting that it is appropriate for college-level physics.
- A later post describes a new technique demonstrated in 2004 for measuring black hole mass, which combines general relativity with classical physics, highlighting advancements in observational methods.
Participants exhibit a mix of agreement and disagreement regarding the appropriateness of using Newtonian mechanics versus general relativity for black hole mass calculations. There is no consensus on the best method, and various approaches are discussed without resolution.
Some calculations rely on assumptions that may not hold in all scenarios, particularly regarding the applicability of Newtonian mechanics in the context of black holes. The discussion also touches on the limitations of not incorporating relativistic effects in certain calculations.
