3.5 FDD head size: size of the gap of the read/write heads
  • Thread starter Thread starter SMD1990
    Gap Head
The discussion revolves around the size of the gap of the read/write heads in 3.5" floppy disk drives, with participants exploring the relationship between gap size and disk density. The conversation also touches on related topics, such as the gap sizes in modern hard drives and the concept of flying height.
  • One participant expresses uncertainty about the gap size of read/write heads in 3.5" floppy disk drives and notes that it may vary with disk density.
  • Another participant suggests that the heads were in physical contact and provides links to external resources discussing floppy drive mechanics and modern hard drive specifications.
  • A different participant mentions that the gap size can exceed bit density by altering the field of the gap relative to the media's movement.
  • One participant clarifies that they are specifically inquiring about the electromagnetic gap size in the heads, rather than the flying height, and notes that the provided resources did not specify the gap size.
Participants do not appear to reach a consensus on the specific size of the gap in 3.5" floppy disk drives, and multiple viewpoints regarding the relationship between gap size and disk density are presented.
There are limitations in the discussion regarding the availability of specific measurements for the gap size, as well as the distinction between flying height and electromagnetic gap size, which remains unresolved.
SMD1990
3.5" FDD head size: size of the gap of the read/write heads
I doubt anyone here knows the answer, but I thought I would ask anyway. I mean, I know not of a better forum on which to ask...
Anyway, does anyone happen to know the size of the gap of the read/write heads of a 3.5" floppy disk drive? Unless I am mistaken, the size should vary depending on what density of disk the drive supports.
I have tried Google, but failed to find anything of relevance. Surely, somewhere out there, the answer is recorded. Still, I was not able to find it.
So, yeah, if anyone knows the answer to this, I would appreciate them sharing the answer with me.
Oh, and if there is any sort of resource containing gap sizes for hard drives, as well... I would be interested in that, too.
Computer science news on Phys.org
I believe these heads were in physical contact:
http://web.mit.edu/2.972/www/reports/floppy_drive_read_write/floppy_drive_read_write.html
However, they also only spun around 300 RPM:
http://hypertextbook.com/facts/2005/GennaAbleman.shtml
As for modern hard drives, Wikipedia says around 3-5 nm:
http://en.wikipedia.org/wiki/Disk_read-and-write_head
As noted, 'disk flying height' gets smaller and smaller with higher and higher bit densities. 4 years ago, the bleeding edge was 13 nm (0.5E-6 inches):
http://www.storagereview.com/guide/opHeight.html
Note that in some cases, the gap size in the direction of data can be bigger than the bit density, which is accomplished by changing the field of the gap faster than the media travels across the gap, leaving a higher density pattern once past the edge of the gap.
MATLABdude, I was not asking about the "flying" height. I was wondering about the size of the gap in the electromagnetic "head" (i.e., 19 µm for an EP VHS head).
In none of your links did I see anything specifying the size of the gap. In the links relating to floppy disk drives, only the speed of rotation was listed (unless I overlooked something, in which case, please correct me).
  • · Replies 33 ·
10K
  • · Replies 22 ·
  • · Replies 19 ·
