How oxidation effects band structure of metals?
The discussion revolves around the effects of oxidation on the band structure of metals, particularly focusing on how the introduction of oxygen can lead to semiconductor behavior in metal oxides. Participants explore the relationship between oxygen, metal ions, and the resulting changes in conductivity and energy levels.
  • One participant notes that many metal elements have multiple valences and can be replaced with similar metals, allowing for various impurity levels that may affect band structure.
  • Another participant clarifies that the discussion involves metal oxides such as silicon oxide (SiO2) and aluminum oxide (Al2O3), which exhibit semiconductor behavior when oxygen is introduced.
  • A participant explains that in metal oxides, metal atoms exist as cations and oxygen as anions, leading to the formation of empty bands lower than the metal valence bands, which can become conductive bands.
  • It is suggested that the electrostatic field created by surrounding oxygen anions can shift the depleted metal bands significantly, affecting the overall band gap.
  • One participant expresses an understanding that as the ratio of oxygen to metal in the crystal increases, the band gap should also increase, although this is presented as an expectation rather than a confirmed outcome.
Participants express various viewpoints on the mechanisms by which oxygen affects the band structure of metals, indicating that multiple competing views remain. There is no consensus on the exact nature of these effects or the implications for conductivity.
The discussion includes assumptions about the behavior of metal oxides and the influence of oxygen on band structure, but these assumptions are not universally accepted or fully resolved among participants.
uLs
Hi everyone,
I'm working on random materials which are coincidencely oxides and showing semiconductor behaviour... Some of these are metals and i suddenly realize MOS (which are practically everywhere). I know them, i know how they work and behave still i can't get to understand the effect of oxygen regarding band structure. I take a quick look to some solid state books in my library but can't come with anything so here i am. Any help will be welcome!
uLs said:
Hi everyone,
oxygen and metal ions have their own bands and their structures depend on type of metal and lattice. many metal elements have multiple valences and can be replaced with similar metals with ease, allowing an infinite ways to introduce impurity levels. not sure what do you mean by "effect of oxygen".
He means silicon oxide SiO2, or aluminum oxide Al2O3 for example.
Apologize if i wasn't clear enough.
What i try to ask is; metals are conductors obviously however when oxygen introduced a band gap occurs and we get semiconductor behaviour with oxides of metals. It is not just Al2O3 but all of the transition metals for instance from Vanadium oxide(and derivatives) to ZnO... Si is already a semiconductor with a band gap around 1eV... So what does oxygen atoms change so there is always a similar difference in the conductivity and energy levels of the formerly conductive metal structures.
Hope i can make myself clear this time,
Regards.
Regards.
in oxides, metal atoms are in the forms of cations and oxygen in the form of anions. in other words, oxygen atoms have an empty band(s) lower than metal valence band(s), and some or even all of the metal valence bands are depleted and become conductive band.
those depleted bands of metal will be significantly shifted up due to the electrostatic field created by surrounding oxygen anions. the other lower metal bands will shift up by a smaller amount. as an over simplification, you can look at it this way: an electron does not interact with itself.
the degree of this depletion can be manipulated to an extent, and the final band gap is highly dependent on it.
Thank you for your through explanation. So in metaloxides, highly electronegative oxygen is the owner of the carriers thus behaving as valance band while emptied bands of the metal becomes conduction band for the new structure. From that what i understand is we can assume that as the oxygen ratio to the metal in the crystal increase, the band gap should also increase. I'll check this expectation. It sound so simple now but it explains a lot to me. Thank you once again :)
  • · Replies 20 ·
11K
