Lorentz Transformations in general
The discussion focuses on the matrix form of Lorentz transformations between inertial frames in special relativity. The transformation matrices for boosts along the x, y, and z axes are provided, including the general form for a boost in any direction represented as L(βx, βy, βz). The transformation is defined by the equation tilde{x}^\mu = \Lambda^\mu_\nu x^{\nu}, where Λ is the Lorentz transformation matrix. The conversation also addresses the misconception that these transformations can be derived by simple multiplication of the individual transformation matrices.
  • Understanding of Lorentz transformations
  • Familiarity with matrix operations
  • Knowledge of special relativity concepts
  • Basic grasp of tensor notation
  • Study the derivation of Lorentz transformations in detail
  • Learn about the properties of tensors in special relativity
  • Explore the implications of Lorentz transformations on time dilation and length contraction
  • Investigate the role of unit vectors in defining boosts in multiple dimensions
Students of physics, particularly those studying special relativity, mathematicians interested in tensor calculus, and researchers working on relativistic physics problems.
Leonhard
Hi, I've been breaking my head on the matrix form of the lorentz transformation between one set of coordinates in one inertial frame [itex](t,x^1,x^2,x^3)[/itex] and what those coordinates will be in another inertial frame [itex](t',x'^2,x'^2,x'^3)[/itex].
Now I understand that if have a set of coordinates in one inertial frame, and we then those coordinates in an inertial frame with a boost along the x-axis, the transformation matrix between those two coordinates will be
[tex]L(\beta \hat{x}) = \left ( \begin{matrix} \gamma & -\beta\gamma & 0 & 0 \\ -\beta\gamma & \gamma & 0 & 0 \\ 0 & 0 & 1 & 0 \\ 0 & 0 & 0 & 1 \end{matrix} \right )[/tex]
A boost along the y-axis and z-axis are given by
[tex]L(\beta \hat{y}) = \left ( \begin{matrix} \gamma & 0 & -\beta\gamma & 0 \\ 0 & 1 & 0 & 0 \\ -\beta\gamma & 0 & \gamma & 0 \\ 0 & 0 & 0 & 1 \end{matrix} \right )[/tex]
and
[tex]L(\beta \hat{z}) = \left ( \begin{matrix} \gamma & 0 & 0 & -\beta\gamma \\ 0 & 1 & 0 & 0 \\ 0 & 0 & 1 & 0 \\ -\beta\gamma & 0 & 0 & \gamma \end{matrix} \right )[/tex]
Now I understand that, in general, a transformation from one set of coordinates to another is given by
[tex]\tilde{x}^\mu = \Lambda^\mu_\nu x^{\nu}[/tex]
Where [itex]\Lambda[/itex] is the lorentz transformation between the two frames of references, but I'm not sure how to derive it. I've been told that a general boost [itex](\beta_x, \beta_y, \beta_z)[/itex] is given by
[tex]L(\beta_x \hat{x} + \beta_y \hat{y} + \beta_z \hat{z}) = \left ( \begin{matrix} \gamma & -\beta_x\gamma & -\beta_y\gamma & -\beta_z\gamma \\ -\beta_x\gamma & 1 + (\gamma - 1)\frac{\beta^2_x}{\beta^2} & (\gamma - 1) \frac{\beta_x\beta_y}{\beta^2} & (\gamma -1)\frac{\beta_x \beta_z}{\beta^2} \\ -\beta_y\gamma & (\gamma - 1)\frac{\beta_y}{\beta_x} & 1 + (\gamma - 1)\frac{\beta^2_y}{\beta^2} & (\gamma - 1)\frac{\beta_y\beta_z}{\beta^2} \\ -\beta_z\gamma & (\gamma - 1)\frac{\beta_z\beta_x}{\beta^2} & (\gamma - 1)\frac{\beta_z\beta_y}{\beta^2} & 1 + (\gamma - 1)\frac{\beta^2_z}{\beta^2} \end{matrix} \right )[/tex]
Is it simple derived by multiplying the transformation matrices?
[tex]L(\beta_x \hat{x} + \beta_y \hat{y} + \beta_z \hat{z}) = L(\beta_x \hat{x})L(\beta_y \hat{y})L(\beta_z \hat{z})[/tex]
Leonhard, You're going to shoot me, but it's obvious by inspection! :smile:
You have the transformations along the three axes. Just use the fact that Ltt is a scalar under a spatial rotation, Lti and Lit are vectors under rotation, and the space-space part Lij is a symmetric tensor. All you have to do is think of two vectors and a tensor that match the cases you are given. This will uniquely determine the solution.
Let β = (βx, βy, βz) = β u where u is a unit vector. Clearly Ltt = γ and both vectors are Lti = - β γ. The only part that takes some thought is the space-space part. It is Lij = I + (γ - 1) u u. Write out the nine components of that tensor in terms of βx, βy and βz, and you have the result.
  • · Replies 19 ·
  • · Replies 33 ·
  • · Replies 54 ·
