Length Contraction of the Universe Surpassing Length of Moving Object?
In summary, a conversation about the effects of traveling at close to the speed of light and the concept of length contraction in the universe. The conversation touches on the idea of the universe being finite or infinite, the ladder paradox, and how observers on a spaceship traveling at near-light speeds would perceive the universe differently. The conclusion is that in an inertial coordinate system, two observers on a spaceship would experience the same events at different times due to the effects of relativity.
Ricky116
A spaceship is of length 1000 meters (to the observer standing in the spaceship).
It is traveling so close to the speed of light that to the observer in the spaceship, the 'length' of the universe has contracted to 900 meters.
Q1: If I am the observer in the spaceship, what do I think the front 100 meters of my ship is 'in'?
This is probably only sensible (if any of this is sensible) if we assume the universe is finite.
I just thought of a photon which as I understand it has the universe at 0 length, and this question popped into my head.
If the answer is "we don't know, what ever is outside the universe" does this mean there is definitely an outside of the universe?
Q2: Is a photon (in its frame) simultaneously in all universes as they are all length 0 and the photon is moving?
I find understanding of relativity extremely hard to keep a hold of, so forgive me if the basic premise of this question is wrong altogether.
EDIT: Oh I see this is my first post. I think I joined a long time ago but I obviously just read. Hi!
You're thinking of the universe as a big version of a sphere, like a great big balloon. It's often regarded as 4-dimensional hypersphere, and if any physical meaning could be attached to your scenario (which I suspect involves a lot more than the usual simple Special Relativity setups), I would conjecture you would observe the tip of your rocket poking into your tail.
This was a fun problem to think about. My conclusion: In an inertial coordinate system that's comoving with the ship, two observers on the ship, one near the back and one near the front, will be next to the same galaxy at the same time. But in the inertial coordinate system that's comoving with that galaxy, those two events will be very far apart in time. The observer near the back would see a galaxy full of stars, but the observer near the front would see the same galaxy at an age when all the fissionable* material has been used up and all that remains are black holes, neutron stars and cold dwarf stars**.
To see this, I suggest thinking of "space" as 1-dimensional, specifically as a circle. If we pretend that there's no expansion of space, the universe would appear as a cylinder in a spacetime diagram. Uh, that sounds like a weird thing to say. How about this: A spacetime diagram depicting the motion of the front and back of the rocket would have to be drawn on a cylinder. To see how the diagram answers the question, we must see that a simultaneity line from the world line of the back of the ship to world line of the front can spiral around the cylinder before it gets there, even though the world lines are very close together on the cylinder. To be honest, I can't visualize this well enough in my head to see this, but I believe it's true. I used some non-rigorous arguments to convince myself, so it's kind of hard to explain.
I haven't tried to figure out what would change (other than the shape of the "cylinder") if we try to include the cosmological expansion in the answer. I suspect that the answer would be essentially the same, except that the big crunch might end the experiment early.
*) Not sure if that's actually a word.
**) I didn't do any calculations. I'm just guessing it would be a very long time.
bcrowell said:
Hi, Ricky116,
Welcome to PF!
This is a version of the ladder paradox: http://en.wikipedia.org/wiki/Ladder_paradox . I think the resolution is the same.
BTW, we don't know whether the universe is finite or infinite: https://www.physicsforums.com/showthread.php?t=506986
-Ben
I've given it a bit of thought and in answering DanR by saying something along the lines of "lets assume the universe is..." I see how I've made the concept harder than it needs to be by placing it in the universe rather than in say, a garage. That made my question a lot more to do with notions of "what is outside of the universe" than I had originally intended.
I have read about the ladder paradox before, but I think I need to give it a good think - it seems to be quite key to my understanding of length contraction here! Thanks!
I love this! I can kind of see what you're saying through taking the ladder paradox / relative simultaneity to the extreme. Glad I could peak your interest.
Fredrik's answer is probably more accurate. The ship wraps around space, but the ends are displaced in time. So you wouldn't see your tailpipe; it's in a different time.
There is much more to this than the ladder paradox and I think it is a very good question.
One aspect that has not been touched on is the visible horizon of the universe. Even if the universe is finite, but much larger than the visible horizon, it seems very unlikely that an observer moving at very close to the speed of light relative to the CMB will see beyond the visible horizon. Any thoughts on this?
yuiop said:
There is much more to this than the ladder paradox and I think it is a very good question...
I was going to say. The garage ends don't join in a loop.
1. How does the length contraction of the universe surpassing the length of a moving object occur?
The length contraction of the universe surpassing the length of a moving object occurs due to the theory of relativity. According to this theory, the fabric of space and time is affected by the presence of massive objects, causing it to contract in the direction of motion. This contraction becomes significant at high speeds, such as those observed in moving objects.
2. Can this phenomenon be observed in everyday life?
No, the length contraction of the universe surpassing the length of a moving object is only significant at extremely high speeds, such as those observed in particles at the subatomic level. It is not noticeable in our everyday lives.
3. How does the length contraction affect the measurements of the moving object?
The length contraction of the universe surpassing the length of a moving object affects the measurements of the object by making it appear shorter in the direction of motion. This is due to the compression of space in that direction, causing the object to appear to be shorter than its actual length.
4. Is this phenomenon related to the expansion of the universe?
Yes, the length contraction of the universe surpassing the length of a moving object is related to the expansion of the universe. The expansion of the universe causes the fabric of space to stretch, while the length contraction occurs due to the presence of massive objects. Both of these phenomena are a result of the theory of relativity.
5. Can the length contraction of the universe surpassing the length of a moving object be reversed?
No, the length contraction of the universe surpassing the length of a moving object cannot be reversed. This phenomenon is a fundamental aspect of the theory of relativity and cannot be altered or reversed. However, it is important to note that the length contraction is only noticeable at extremely high speeds and is not relevant in most situations.
