How to integrate complicated differential equation
The discussion revolves around the integration of the function ∫ -y³e^(y²/2) with a focus on techniques for solving complicated differential equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods including integration by parts and u-substitution. Some suggest factoring and manipulating the expression to facilitate integration, while others propose differentiating a related function to find the integral.
The discussion is active with multiple participants sharing their attempts and suggestions. There is no explicit consensus on a single method, but several viable approaches are being explored.
Participants are working under the constraints of homework rules, which may limit the extent of guidance provided. There is a recognition of the complexity of the integral involved.
trojansc82
I need to integrate ∫ -y3ey2/2
Integration by parts
I have tried several times, I am unable to find the correct solution, which is:
-yey2/2 + 2ey2/2 + c
I think you can use u substitution. Let u = y^2, du = 2y. If you factor that y^3 at y^2 * y it should work. You might have to also do integration by parts afterwards.
Try a u-substitution.
Here is a possibly slicker method, calculate:
[tex] \int ye^{ay^{2}}dy[/tex]
This should be very straight forward, the result should be a function of a, all you do now is differentiate the result with respect to a and then set a=1/2.
