Can Optical Computing Outpace Quantum Computing in Future Technology?
  • Thread starter Thread starter Claude Bile
    Computing Optical
The discussion revolves around the potential of optical computing compared to quantum computing, exploring the capabilities, limitations, and future prospects of optical computing technology. Participants delve into the technical aspects of optical devices, their applications in computing, and the challenges faced in their development.
  • Claude introduces optical computing, highlighting the limitations of optic fibers and the potential of photonic crystals for guiding light.
  • Claude mentions the need for optical data storage solutions, such as holographic storage and nonlinear Fabry-Perot cavities, noting their current drawbacks.
  • Another participant expresses interest in the speed advantages of optical computing, questioning why research in this area is limited compared to electrical microprocessors.
  • This participant also raises concerns about the need for optical memory and transistors to implement logic gates in optical computing systems.
  • One participant expresses skepticism about optical computing due to the constraints imposed by photon wavelength and energy, suggesting that electrons are more manageable for computing purposes.
  • This skepticism is echoed by another participant who emphasizes the challenges of size and power consumption in optical devices compared to electronic devices.
  • A later reply challenges the reasoning about power consumption, arguing that optical signals do not directly consume power but serve as data carriers.
  • Another participant clarifies their earlier point, stating that the size of optical signal processing chips and the power required for optical amplification are significant concerns.
Participants express a mix of interest and skepticism regarding optical computing. While some see potential advantages, others highlight significant challenges and limitations. No consensus is reached on the viability of optical computing compared to quantum computing.
Participants note various technical limitations, including the size constraints of optical devices, the need for compatible optical memory, and the power requirements for optical signal processing. These factors contribute to the ongoing debate about the future of optical computing.
Claude Bile
People seem very quick to proclaim Quantum Computing as the solution to faster computers, however the development of Optical Computers rarely rate a mention. The motivation behind this thread is to give some awareness as to what optical computing is and what it is capable of and hopefully invite some discussion.
The first widely used photonic waveguides were optic fibres which were developed around 1980. Optic fibres are an excellent means of data transfer over long distances. Optic fibres have also been used to construct some very clever photonic devices (splitters, multiplexers and circulators for example), however there is a fundamental limitation in using optic fibres in minaturised circuits.
This limitation is due to the way optic fibres guide light. Fibres guide light through total internal reflection (devices such as these are often termed 'index guided'). If one bends a fibre too much (as is necessary when minaturising photonic circuitry), the fibre will no longer guide light efficiently.
A solution to this problem emerged in the form of photonic crystals, that guide light using the phenomenon of photonic bandgaps (which are not unlike electronic bandgaps). If light of a particular frequency that falls within a photonic band gap, is incident on a photonic crystal, the photon will be reflected (the photon effectively satisfies Bragg's condition). If one creates a defect through the crystal, the photon will be guided. This method of guiding light does not suffer from the same drawbacks as index guided devices, however there is the issue of fabricating such crystals.
In order for a band gap to be present at a particular wavelength, the dielectric constant of the crystal must be modulated in dimensions of the
order of half that wavelength. Thus to guide wavelengths commonly used in optical devices (1.55 microns), the modulations must be of the order of hundreds of nanometers.
In addition to guiding light on a small scale, there needs to be some sort of way to store data optically (i.e. the optical equivalent of a transistor). One such proposed method is holographic storage, however it suffers from the drawbacks of being short-lived (about a day or so) and must be kept very cool (around 100 K) to work properly. Nonlinear Fabry-Perot cavities are another proposed solution, however they are expensive to make and difficult to align and operate. The difficulty is in that most optically bistable materials are only bistable under very specific conditions and usually at a low temperature.
Despite these experimental obstacles, optical computing, in my opinion, is closer to being a reality than quantum computing.
Okay, I'm running out of time, so I will wrap up discussion here for now. Please feel free to discuss anything mentioned in this post, or if you have an opinion regarding optical vs quantum computing, I would be interested to know.
Regards,
Claude.
Computer science news on Phys.org
Could you please describe in a few simple words what is quantum computing?
Hi Claude Bile, your presentation of optical computing seems interesting and promising. Since light travels at the maximum speed, it would be able to transfer data at tremendously high speeds. How could this technique be used for computer microprocessors? Till now microprocessors have reached a maximum clock rate of 3GHz, all this achieved with electricity. Research to speed up microprocessors has focused on shortening the paths that electricity follows in a fetch-execute cycle. This is a complex task, since there is a cobweb of paths and circuits and it is difficult to predict the route. Other techniques have been to use multiple microprocessors working in parallel, piping, using fast cache memories and so on. These trends however promise only minor advances. I don't know why so little research is being made in the so-called optical computing, which might result in tremendous CPU speeds, maybe several THz or further.
Apart from optical busses (paths) we would also need optical memory. Your suggestion of holographic memories might be a solution, but isn't it slow? It might prove to be a major bottleneck. What about transistors, which also need to be optical, to implement switches for logic gates (AND, OR, NOT )? I don't know any. Also all the computing system has to transit from electric to optical (including peripherals). If this could be done we would have achieved tremendous results in computing speeds.
In any case I suspect that in practice we wouldn't need much faster microprocessors. Major bottlenecks have become memories like RAM, ROM, etc. Also statistics show that with modern computers and advances in CPU speeds most of the time is spent in performing Input/Output operations in peripheral devices, especially the hard disk. These peripherals have become a major bottleneck. If we need to speed up the flow of data (like in CPUs) we also have to improve in parallel the performance of memory, disks, printers, network connections (where we already have introduced optical fibers), and so on. What's your opinion?
This is definitely an interesting and thought provoking subject. My opinion regarding optical computing is that most people, including myself, are skeptical due to two major reasons: compared to electron, the wavelength of a photon is too long, and also its energy is too high. Both place a constraint on how small the end device can be, and size do matter, because bulky optical devices consume too much power. In addition, all of the optical devices demonstrated to date (or those I'd read about) that are capable of performing logic operation are based on inteferometric configuration, which again places a lower limit on the device size.
Apart from that, popular research topic in quantum computing, like spintronic for instance, interface with current microelectronic technologies much easier compared to optical computing. So I think as far as computing is concerned, electron still has the upperhand. Photons work best in transmitting information, but my gut feeling is that being boson, it's much more difficult to manipulate compared to electron.
OldTree, I cannot follow your reasoning, or you are unclear. You say that Both place a constraint on how small the end device can be, and size do matter, because bulky optical devices consume too much power.. I don't know why this could be. The end devices don't take the power from these light signals, but from other sources. These light signals serve only for data and can be amplified to any magnitude we need.
Opps..apologies for being unclear. By end devices I'm actually referring to the final design of these optical signal processing chips. Just take amplifier as an example, semiconductor optical amplifier is much much larger than an electrical op-amp. And the power it takes to amplify optical signal is much higher than what it takes to amplify electrical signal for a given magnitude.
Maybe, I didn't know that. But does it have any link with electron wavelength and energy being smaller than that of the photon?
  • · Replies 0 ·
  • · Replies 0 ·
