What is the weight percent of NH3 in the window cleaner?
  • Thread starter Thread starter Mag
    Titration
The weight percent of NH3 in a window cleaner can be calculated using titration data. A 10.231g sample of the cleaner was diluted with 39.466g of water, and 4.676g of this solution was titrated with 14.22mL of 0.1063 M HCl to reach a bromocresol green endpoint. By determining the millimoles of HCl used, which equals the millimoles of NH3, and using the formula for weight percent, the concentration of ammonia in the cleaner can be accurately calculated.
  • Understanding of titration techniques
  • Knowledge of molarity and millimoles
  • Familiarity with weight percent calculations
  • Basic chemistry concepts, including chemical formulas and equivalents
  • Calculate the millimoles of HCl used in the titration
  • Determine the weight percent of NH3 using the formula: (mass of NH3 / mass of sample) x 100
  • Explore the properties and applications of bromocresol green as an indicator
  • Research the implications of ammonia concentration in cleaning products
Chemistry students, laboratory technicians, and anyone involved in analytical chemistry or formulation of cleaning products will benefit from this discussion.
Mag
[SOLVED] titration need help getting started
A 10.231g sample of window cleaner containing ammonia was diluted with 39.466g of water. Then 4.676g of solution was titrated with 14.22mL of 0.1063 M HCl to reach a bromocresol green endpoint. Find the weight percent of NH3 (FW 17.031) in the cleaner.
I keep trying to find someway of getting the 4.676g solution to a volume amount so i can find the mmol of the analyte.
thanks
mag
Chemistry news on Phys.org
Mag said:
(snip)Find the weight percent of NH3 (FW 17.031) in the cleaner.(snip)
Do you need to calculate a volume?
You may start from here, as this sentence tells you that their millimole amounts are equal. You can find millimoles by multiplying volume by concentration, as [tex]\displaystyle mL\times \frac {mmol}{mL}[/tex] gives [itex]\displaystyle mmol[/itex]. If 4.676 g of that solution is equal to the millimoles of [itex]\displaystyle NH_3[/itex], you can calculate a weight percentage from there.
10K
12K
11K
