Hyperbola and Ellipse's definition
An ellipse is defined as the set of all points where the sum of the distances from two fixed points (foci) equals a constant, specifically 2a. Conversely, a hyperbola is defined by the difference of the distances from the same two foci equaling a constant, also 2a. The equations for these conic sections are given by the standard forms: for an ellipse, \(\frac{x^2}{a^2} + \frac{y^2}{b^2} = 1\) and for a hyperbola, \(\frac{x^2}{a^2} - \frac{y^2}{b^2} = 1\). The distinction lies in the positioning of the foci relative to the vertices, with foci inside the vertices for ellipses and outside for hyperbolas.
  • Understanding of conic sections
  • Familiarity with the standard forms of ellipse and hyperbola equations
  • Basic knowledge of distance formulas in coordinate geometry
  • Concept of foci and vertices in conic sections
  • Study the derivation of the standard forms of conic sections
  • Explore the geometric properties of ellipses and hyperbolas
  • Learn about the applications of conic sections in real-world scenarios
  • Investigate the relationship between eccentricity and the shape of conic sections
Students studying geometry, mathematics educators, and anyone interested in the properties and applications of conic sections, particularly ellipses and hyperbolas.
flyingpig
An ellipse is a set of all points from two points called a focus (together a foci) has the sum of 2a
|d1 + d2| = 2a
A hyperbola is the same except it is difference.
Now my question is, just who came up with these definitions that it must equal to 2a?? Because if I don't remember that it is 2a, then I will never be able to understand the formulas.
attempedt at daydreaming an answer, but failed.
An ellipse is a figure such that the sum of the distances from a point on the graph to the two foci is a constant. A hyperbola is a figure such that the differences of the two distance from a point to the two foci is a constant. The fact that that constant is "2a" comes only after you write the ellipse as
[tex]\frac{x^2}{a^2}+ \frac{y^2}{b^2}= 1[/tex]
or
[tex]\frac{x^2}{b^2}+ \frac{y^2}{a^2}= 1[/tex]
with a the length of the "major semi-axis" so that 2a is the distance between the two vertices along the longer axis.
To see that, set up and ellipse with major axis along the x-axis, center at (0, 0). Then the two foci are at (f, 0) and (-f, 0), the vertices along the line between foci are at (a, 0) and (-a, 0). The distance from vertex (a, 0) to the focus (f, 0) is a- f. The distance from that vertex to the other vertex is a from (a, 0) to the center, (0, 0), is a, of course, then the distance from (0, 0) to the other focus, (-f, 0), is f for a total distance from (a, 0) to (-f, 0) of a+ f. The total distance from (a, 0) to the two foci is (a- f)+(a+ f)= 2a. Given that that sum of distances is a constant, that constant must be 2a.
Similarly the constant for the hyperbola is 2a only after you write the hyperbola as
[tex]\frac{x^2}{a^2}- \frac{y^2}{b^2}= 1[/tex]
or
[tex]\frac{y^2}{a^2}- \frac{x^2}{b^2}= 1[/tex]
with a the distance from the center of the hyperbola to s vertex.
Of course, the difference between an ellipse and a hyperbola is that the foci of an ellipse are inside the vertices while for a hyperbola, they are outside.
Again, set up the hyperbola so its center is at (0, 0), its vertices are at (-a, 0) and (a, 0), its foci at (-f,0) and (f, 0). The distance from (a, 0) to (f, 0) if f- a (the foci are now outside so f> a). The distance from (a, 0) to (-f, 0) is the distance from (a, 0) to (0, 0), a, plus the distance from (0, 0) to (-f, 0), which is f. The distance from (a, 0) to (-f, 0) is a+ f. The difference of those two distances is (a+ f)- (f- a)= 2a.
11K
10K
