Solving 6n^2-18n+16 with Pell's/Diophantus Equation
  • Thread starter Thread starter 76Ahmad
The discussion revolves around solving the equation 6n^2-18n+16 = m^2, with a focus on approaches related to Pell's and Diophantine equations.
  • Participants explore the transformation of the original equation into a different form and discuss the implications for solving for n and m. There are questions regarding the conditions for integer solutions and whether rational solutions are required.
Participants have provided various insights and approaches, including references to external resources. There is ongoing exploration of how to derive integer values for n and the relationship between m and n, with some participants suggesting specific forms of the equation that relate to Pell's equation.
There is a mention of potential constraints regarding the nature of solutions (integer vs. rational) and the specific forms of the equations being discussed, which may affect the applicability of Pell's equation.
76Ahmad
Solve the equation 6n^2-18n+16 = m^2
the solution should be from pell's equation or Diophantus equation:
a^2 x^2 + c = y^2
I put my equation in the form: 3/2 (2n-3)^2 + 5/2 = m^2
So any further idae please
Thanks
For which variable should you solve? I assume for n, then from 3/2 (2n-3)^2 + 5/2 = m^2 I get (2n-3)^2 = 2/3 ( m^2 - 5/2 ) and then 2n-3 = +- \sqrt{2/3 ( m^2 - 5/2 )}, so n = 3/2 +- 1/2 \sqrt{2/3 ( m^2 - 5/2 )}. If you should solve for m, m = +- \sqrt{3/2 (2n-3)^2 + 5/2}.
But since that's trivial, I assume there are further conditions on m and n. Should they be rational? Or integers?
An integer solution is, for example, n = 0 and m = +-4, or n = 1 and m = +-2.
OK, thanks for help
but when n = 3/2 +- 1/2 \sqrt{2/3 ( m^2 - 5/2 )}
how can i find the integer values for n?
(I assume you solve it without using pell equation)
I saw it, but the problem i think thay always have the factor of X^2 =1
and in my example dont
what if i change the form of my equation to:
2/5 m^2 - 3/5 (2n-3)^2 = 1
this is close to Pell equation form x^2 - P*y^2 = 1
Yes, I see. I'm sorry, don't know more.
From n = 3/2 +- 1/2 \sqrt{2/3 ( m^2 - 5/2 )}, you see that 2/3 ( m^2 - 5/2 ) must be a perfect odd square for n to be integer, so you can equally solve 2/3 ( m^2 - 5/2 ) = (2k+1)^2, with k = 0,1,2,... This can be reexpressed as m = +- \sqrt{6 k^2 + 6 k + 4}, so you can in principle find all solutions by calculating the above for all k and checking if it gives you an integer m ...
For k < 200, you have luck for k = 0 with m = 2, k = 1 with m = 4, k = 6 with m = 16, k = 15 with m = 38, k = 64 with m = 158, k = 153 with m = 376.
In principle, this gives you all solutions, but I don't see any general formula. For me, the only thing I can see is that 2k < m < 3k for large k.
