| New Reply |
How does conservation of charge work? |
Share Thread | Thread Tools |
| Jun26-11, 08:14 PM | #1 |
Example: A conducting sphere X that has an initial charge of +2.0 × 10–8 C and an identical conducting sphere Y that has an initial charge of –3.0 × 10–8 C are touched together. After they are separated, the charge on sphere X is?
Answer: (–5.0 × 10–9 C) And what I would have done is tried to balance them out by adding them together and dividing by 2, but either way I can't understand how they got an exponent of "-9" Not a homework problem, I just need to understand what's going on here, and how to come up with solutions to solving this type of problem with charged particles. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jun26-11, 09:13 PM | #2 |
if capacitance of two sphere is different say C1 and C2 then we use the point that potential on both the sphere should equal(as they are in contact).V1=V2 => Q1/c1=q2C2 q and c represent their charge and capacitance respectively. Hope my my answer helps. |
| Jun26-11, 09:15 PM | #3 |
Mentor
| Jun26-11, 10:00 PM | #4 |
How does conservation of charge work?@jtbell I got 5.00x108 Dividing that by 2 would equal 2.50x108 I'm still confused though, as the way I was doing it must be wrong, so doing that is irrelevant. I was keeping to the numbers as if they were absolute values. |
| Jun26-11, 10:12 PM | #5 |
Recognitions:
| Jun26-11, 11:41 PM | #6 |
I know, There's just that number of charges MORE as those numbers are only net charges, but how would you solve this? Still doesn't answer that
| Jun27-11, 12:12 AM | #7 |
They are identical spheres and we can assume symmetry at work in this problem. So we know that after touching and drawing them apart that they should have the same net charge. We know this because a conductor is an equipotential surface and so when they are brought in contact the amalgamation of the two spheres becomes a single equipotential surface. Thus, the charge becomes evenly distribtuted across the two spheres when they come in contact (via symmetry and equipotential).
Next, how much charge is there? When you bring the two spheres together, what is the net charge that is distributed across the surfaces? Now when you separate the spheres, what is the net charge distributed on each sphere? As Nabeshin stated, you need to remember to keep track of the sign. |
| Jun27-11, 12:21 AM | #8 |
(You aren't adding correctly) |
| Jun27-11, 08:00 AM | #9 |
Alright, so I added them as If they weren't absolute values and ended up with the smaller number (exponent -9) I should have assumed that was the case since there's no other way that I would end up with a smaller number than to end up with a smaller number through the adding process, and the only way to do that would to be to minus the 3. (Which would also give me a "-"5 result...)
Guess I just wasn't thinking: [(+2.0 × 10-8) + (-3.0 x 10-8)] ÷ 2 = -5.0x10-9 |
| New Reply |
| Tags |
| charge, conservation, law |
| Thread Tools | |
Similar Threads for: How does conservation of charge work?
| The conservation of energy, why does it work? Negative work vs positive work | Introductory Physics Homework | 54 | ||
| Charge conservation | Classical Physics | 6 | ||
| Conservation of charge, but not conservation of energy | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Charge Conservation | General Physics | 1 | ||
| The work required for adding a charge to an infinite charge distribution | Advanced Physics Homework | 1 | ||
