Solve second order diff eq with substitution
The discussion revolves around solving a second-order differential equation of the form xy'' + 2y' = 12x² using the substitution u = y'. Participants explore the implications of this substitution and the resulting transformations in the equation.
  • The original poster attempts to understand the reasoning behind the transformation of y'' into u(du/dy) and questions the application of the chain rule in this context. Other participants provide clarification on the chain rule and suggest alternative methods for solving the equation without the substitution.
Participants are engaged in clarifying the mathematical concepts involved in the substitution and its implications. There is an acknowledgment of the original poster's confusion, and while no explicit consensus is reached on the correctness of the solution, some guidance is offered regarding checking the solution against the original equation.
The problem is presented as part of a homework assignment, and participants are mindful of the constraints that prevent them from looking up solutions directly.
Asphyxiated
Solve:
[tex]xy''+2y'=12x^{2}[/tex]
with
[tex]u=y'[/tex]
if you have:
[tex]y'+P(x)y=Q(x)[/tex]
then your integrating factor is:
[tex]I(x)=e^{\int P(x) dx}[/tex]
The only reason I was able to solve this is because I stumbled upon a similar post here but instead of pulling up a thread from over a year ago i decided to post my specific question.
So if:
[tex]xy''+2y'=12x^{2} \hookrightarrow y''+\frac{2y'}{x}=12x[/tex]
and
[tex]y'=u \hookrightarrow y''=u\frac{du}{dy}[/tex]
I do not understand why y'' is equal to this. The way I read y'' is d2y/dx2 so why is it u*du/dy as the derivative on the right side and not d/dx? And! why is the derivative of u with respect to y u*du/dy and not just du/dy.
Maybe I have just forgotten something simple from differential calculus but I can't make sense of it on my own. I am not claiming that what is written in TeX above is wrong because the problem seems to work out, I just don't know why that is the way to do it.
Anyway, if we make the substitution:
[tex]u\frac{du}{dy}+\frac{2u}{x}=12x[/tex]
then
[tex]I(x)=e^{\int \frac {2}{x} dx} = e^{2 ln|x|}=x^{2}[/tex]
then multiply both sides by I(x):
[tex]x^{2}u\frac{du}{dy}+2xu=12x^{3}[/tex]
which is:
[tex]\frac {d}{dx} (ux^{2})=12x^{3}[/tex]
[tex]ux^{2}=\int 12x^{3} dx =3x^{4}+C_{1}[/tex]
[tex]u=3x^{2}+ \frac{C_{1}}{x^{2}}[/tex]
[tex]\frac {dy}{dx}=3x^{2} + \frac {C_{1}}{x^{2}}[/tex]
[tex]y= \int 3x^{2}+\frac{C_{1}}{x^{2}}dx = x^{3}-\frac{C_{1}}{x}+C_{2}[/tex]
if that is right please tell me why. I just followed by example from someone elses work.
That's just the chain rule.
[tex]y'' = \frac{du}{dx} = \frac{du}{dy}\frac{dy}{dx} = u\frac{du}{dy}[/tex]
I'm not sure why you'd do it that way, though. You could simply write
[tex]x u' + 2 u = 12x^2[/tex]
and solve it with the same integrating factor without the unnecessary complication of invoking the chain rule.
oh haha alright. I guess I was confused by the substitution of y'=u again for some reason.
Thanks for the reminder on that!
So I assume this is a correct solution? It's an even problem so I can't look it up.
I didn't see anything obviously wrong, but I didn't look that closely either. You can always check your answer by plugging it back into the original differential equation to see if it's satisfied.
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 18 ·
