Does Heating an Ammonia/Water Solution Revert All Ammonium Back to Ammonia?
  • Thread starter Thread starter Somes J
The discussion centers on the behavior of an ammonia/water solution when heated, specifically whether ammonium ions (NH4+) revert entirely to ammonia (NH3). It is established that heating the solution in an open container drives off ammonia gas, shifting the equilibrium towards the formation of NH3, but not all NH4+ converts back to NH3 unless the solution is boiled to dryness. Additionally, the presence of trace ammonium salts in the residue is noted, and the implications for storing ammonia-containing waste products are highlighted, particularly regarding pressure buildup and safety risks.
  • Understanding of chemical equilibrium principles
  • Knowledge of ammonia and ammonium ion chemistry
  • Familiarity with distillation processes and limitations
  • Basic concepts of vapor pressure in solutions
  • Research the principles of chemical equilibrium and Le Chatelier's principle
  • Study the properties and reactions of ammonia and ammonium ions
  • Learn about safe storage practices for ammonia-containing waste
  • Investigate the limitations of distillation for ionic compounds
Chemists, chemical engineers, environmental scientists, and safety professionals dealing with ammonia and its derivatives will benefit from this discussion.
Somes J
When ammonia dissolves in water some of it reacts to form ammonium and hydroxide ions:
NH3 + H2O = NH4+ + OH-
http://scifun.chem.wisc.edu/chemweek/pdf/ammonia.pdf"
What happens if you then heat or boil the solution, driving off the ammonia? Does all the NH4+ turn back into NH3?
Just something I was wondering about, I can't seem to find the answer on Google.
Thanks.
Chemistry news on Phys.org
The first problem you would have is separating the water and ammonia that didn't react from your desired products. I can't think of any way to do that which wouldn't encourage them to react back to water and ammonia (i.e. time, mixing).
Nitrogen prefers 3 bonds and oxygen 2. Therefore, the amount of formation of the NH4+ and OH- is going to be extremely small so it would not be practical to distill. But if you were able to somehow do this I believe the hydroxyl group would vaporize first because it's lighter (17 vs 18 g/mol). Also, both of the components would probably boil at close to the same temperature (a guess based off molecular weight), making distillation nearly impossible.
Sorry, but most of that is pretty confused.
First of all, the OP is exactly right. Ammonia is a gas at RT, so separation of the water and ammonia is trivial ... if you heat the solution in an open container, you will drive off NH3(g), pushing the equilibrium back to the left. So you would expect a temperature-dependent pH for the solution. However, you will never get quite all of the NH4+ converted back to NH3, at least until you boil the solution to dryness. Still, you will probably have some trace ammonium salts left in the residue.
As a side note, the above phenomenon can have real consequences when storing basic waste products containing ammonia. If the storage area temperature rises, you will build pressure in your waste containers if they are not properly vented, which risks exposing people to the fumes, or in the worst cases, explosion of the containers. On the other hand, proper venting is not straightforward, since the ammonia vapor is highly pungent and must not be vented into a human air supply.
Second, why would you think it is even theoretically possible to distill ions? What is the vapor pressure of the hydroxide ion in aqueous solution? If you were to "distill" the solution, you would end up boiling off the water until ionic crystals were left. Exactly what ionic compounds would be left depends on the trace ions in the water, but you would probably have a mixture consisting primarily of solid sodium hydroxide and ammonium chloride, since sodium and chloride ions are pretty much ubiquitous.
35K
  • · Replies 20 ·
9K
