What are the pitfalls in implementing binary search?
The discussion centers on the pitfalls of implementing binary search in Pascal, specifically highlighting a flaw in the algorithm when Low equals High. The provided Pascal code incorrectly sets FOUND to true even when the Key is not present in the array. The participants agree that the algorithm fails when the loop executes with Low equal to High, leading to false results. Two corrective methods are proposed: modifying the condition for updating Low and changing the FOUND assignment to directly compare the Key with the array element.
  • Understanding of binary search algorithms
  • Familiarity with Pascal programming language
  • Knowledge of array indexing and its implications
  • Basic algorithm analysis skills
  • Review the implementation of binary search in different programming languages
  • Learn about edge cases in search algorithms
  • Explore algorithm optimization techniques
  • Study the differences in array indexing across programming languages
Software engineers, computer science students, and anyone interested in algorithm design and optimization will benefit from this discussion.
dalcde
On the website http://stackoverflow.com/questions/504335/what-are-the-pitfalls-in-implementing-binary-search, it states that the Pascal code (note that in Pascal, the array indexing starts with 1)
Code:
PROCEDURE BinarySearch (A         : anArray,
                        Key       : INTEGER,
                        VAR Found : BOOLEAN;
                        VAR Index : anArrayIndex);
Var Low, High : anArrayIndex;
BEGIN
   LOW := 1;
   High := Size;
   REPEAT
      Index := (Low + High) DIV 2;
      If Key < A[Index]
         THEN High := Index - 1
         ELSE Low  := Index + 1
   UNTIL (Low > High) OR (Key = A[Index]);
   FOUND := (Low <= High)
END;
has the pitfall that when the final iteration starts with Low=High, then it will return
Code:
FOUND=true
even if the Key is not found in the array.
I've tried with the following example and didn't find a mistake:
A=[3]
Key=2
Low=1
High=1
Index=1
Since 2<3, Key < A[index] and
High=Index-1=0
Since Low>High, the loop is terminated
Low<=High isn't true so FOUND is set to false, which is a correct answer.
Technology news on Phys.org
I have noticed that when the key is 3, we have
Key=3
Low=1
High=1
Index=1
Key<A[1] is false, hence
Low =Index+1=2
Since Low>High, loop ends
FOUND=(Low<=High)=False
This is an example in which the algorithm fails. Am I correct?
There's a lot wrong with this and it's clear either (a) an engineer/scientist/mathematician wrote this without a clue or (b) this is an exercise devised by a computer scientist. Either way...
Trivially, the pitfall they mention does not hold and the problem you found does hold. If the loop body ever executes with low = high, the condition will fail (since either low is incremented or high is decremented) and high < low holds. So whenever the loop gets to the point where low = high, the algorithm will return false, regardless of whether the element at the position index = low = high is the target or not.
There are two methods to fix this. Note that the problem only exists where there is an element in the array that matches the target and we happen to test it at the very last possible iteration of the loop. So...
Method #1: Change "ELSE LOW := INDEX + 1" to "IF key > A[index] THEN LOW := INDEX + 1".
Method #2: Change "FOUND = (LOW <= HIGH)" to "FOUND = (key = A[index])".
Let me know if I goofed.
  • · Replies 36 ·
  • · Replies 75 ·
15K
