A basic electrical question, but i can't work it out.
  • Thread starter Thread starter MaximumTaco
    Electrical Work
The discussion focuses on calculating power dissipation in a resistor connected in parallel with a DC battery and a constant current source. The correct approach involves recognizing the superimposed current components from both the voltage source and the current source. The power dissipation can be calculated using the formula I^2 * R, where I is derived from the voltage of the DC battery divided by the resistance. Additionally, the application of Millman's Theorem is recommended for more complex scenarios involving internal resistances.
  • Understanding of DC circuit theory
  • Familiarity with Ohm's Law (V = IR)
  • Knowledge of Millman's Theorem
  • Basic concepts of power dissipation in electrical components
  • Study Millman's Theorem in detail
  • Learn about internal resistance in batteries
  • Explore power dissipation calculations in parallel circuits
  • Investigate the effects of superimposed currents in circuit analysis
Electrical engineers, students studying circuit theory, and anyone involved in analyzing power dissipation in parallel electrical circuits.
MaximumTaco
Say i have a DC battery, in parallel with a constant current source, and a resistor in parallel too.
I want to find the power dissipation in the resistor.
Do i consider that there are 2 current components superimposed, one from the voltage source
(I = v/r) and one from the current source, and then use I^2 *R?
Thanks.
if everything is in parallel, no matter what you put, the voltage in the parallel is given by the voltage of the dc battery so the current in the resistor is V/R.
In real word however, each battery has an internal resistor in series and a current generator has a resistor in parallel, so you should consider it.
In this case you can use the Millman´s Theorem, very easy.
Byez
  • · Replies 18 ·
