Help finding the derivative of rational/radical function
The discussion revolves around finding the derivative of the function F(x) = (-1/sqrt(2x)) + 2x, which involves both rational and radical components. Participants are exploring various methods to approach the derivative calculation.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants suggest rewriting the function to simplify the differentiation process. There are questions about handling the radical and the limit definition of the derivative. Some express uncertainty about the correct approach to finding the least common denominator (LCD) and rationalizing the numerator.
The discussion is active, with participants sharing their attempts and questioning specific steps in the differentiation process. Some guidance has been offered regarding breaking down the function into simpler components for differentiation, but there is no explicit consensus on the best method yet.
Some participants mention feeling rusty with radicals and limits, which may affect their confidence in the calculations. There is also a recognition of the complexity involved in simplifying the expressions derived from the limit definition.
jmanna98
Please help me break down the first couple parts of this derivative question. This question gets a bit ugly:
Find the derivative of F(x)=(-1/sqrt(2x)) +2x
You can rewrite F(x) = 2x - (2x)^(-1/2)
Try taking the derivative of this expression.
ya but then how do you multiply out (x+deltax)^.5?
So, do you need to find the derivative by finding the limit: [itex]\displaystyle \lim_{\Delta x \to 0} \frac{F(x+\Delta x)-F(x)}{\Delta x}\,?[/itex]
If so, you'll find it handy to rational the numerator.
Yes as delta x approaches zero. I know there is goig to be some conjugate or LCD stuff going on but i got stuck
So far you haven't shown any work at all. What have you tried to do and where, exactly, do you have a problem?
The first thing I did was sub the function into the derivative formula which made a huge mess of a problem to simplify.
[(-1/sqrt2(x+deltax)) +2(x+deltax)] - [(-1/sqrt2x)+2x] all over deltax.
I am a little rusty on working with radicals and tried a few things that ended up in a mess but I am thinking that I should simplify the numerator of this first by finding the LCD of the rational expressions in the numberator of the whole problem. LCD:(sqrt2(x+deltax))(sqrt2x)? Then multiply by the conjugate? I sort of feel on the right track but at the same time I feel that my LCD is incorrect for some reason.
Let's look at your difference quotient in LaTeX.
[tex]\frac{\displaystyle \frac{-1}{\sqrt{2(x+\Delta x)}}-\left(\frac{-1}{\sqrt{2(x)}}+2x\right)}{\Delta x}\quad\to\quad \frac{\displaystyle \frac{-1}{\sqrt{2(x+\Delta x)}}-\frac{-1}{\sqrt{2(x)}}}{\Delta x}+\frac{2(x+\Delta x) -2x}{\Delta x}[/tex]
Instead of trying to find the limit of all of the parts of F(x) at one time, break F(x) into two pieces: 2x and the radical. Since the derivative of a sum is the sum of the derivatives of the components, you can calculate the two limits and add them together.
  • · Replies 23 ·
