Feynman's Sum Over Paths? (n00b question)
  • Context: Graduate
  • Thread starter Thread starter Gecko
    Sum
This discussion revolves around Feynman's Sum Over Paths theory, exploring its implications in quantum mechanics, the nature of path integrals, and the mathematical challenges associated with defining these integrals. Participants raise questions about the interpretation of paths, the mathematical foundations, and the historical context of Feynman's contributions.
  • Historical
  • Some participants question whether the paths in Feynman's theory represent what a particle could take or what it actually took, noting the existence of infinitely many paths.
  • Others argue that Feynman's perspective is that particles take all paths, which are not observable, and that in specific experimental situations, the number of paths can be reduced.
  • A participant raises concerns about how to define the path integral, suggesting it is a complex mathematical issue not fully explored in physics literature.
  • Another participant mentions attempts to define the path integral using algebraic topology and homotopy, indicating a deeper mathematical connection to physics.
  • Some participants emphasize that the effectiveness of the path integral in quantum field theory is more important than understanding its mathematical foundations.
  • There is a discussion about the historical context of path integrals, with claims that Feynman did not invent them but popularized their use in physics, while Dirac is credited with their original conception.
  • One participant explains the process of calculating probabilities using path integrals, emphasizing the addition of complex numbers associated with paths and how they can cancel each other out.
  • Another participant references Feynman's lectures, highlighting the concept of "little arrows" in the context of quantum mechanics.
Participants express differing views on the interpretation and implications of Feynman's Sum Over Paths theory, with no consensus reached on the nature of path integrals or the historical contributions of various physicists.
Participants note the complexity of defining path integrals and the mathematical challenges involved, indicating that the discussion may depend on specific definitions and assumptions that are not fully resolved.
Gecko
what exactly happens in this theory? is it a list of possible paths that the particle COULD take, or is it the paths the particle DID take? also, wouldn't there be an infinite amount of paths? how do these cancel out?
Feynmann's perspective is that the particle does take all the paths. But they are not "observable" so you can't tell, and argumants may arise. Yes there are infinitely many paths in the general case, although in particular experimental situations they reduce the number of possible paths to just a few. For how they can all cancel out, I highly recomment you read Feynmann's little book QED.
selfAdjoint talk write.
But the problem is bigger .
the problem is how we can define this integral?
That's a tricky mathematical issue.Physics books dealing with path integral do not explore the depth of this notion.I didn't either,though i was taught QFT by a guy who graduted math.He simply said:"it's not an ordinary integral".
That's physics,basically it uses mathematical results without questioning the way those results have been gotten to.
But actually, the scientists try to define the path integral with algebric topology and homotopy
For the sake of physical theory (meaning QFT:SM,its supersymmetrical generalizations and supergravity),it's not WHY does this path intergral quantizatin works (which has to do with its mathematical grounds and their connections to physics),it matters that IT WORKS,and so far,gives results corresponding to measured values.I don't know wether (super)string quantization via path integral poses problems with what lies behind this fundamental concept (mathematics,I mean).If it does,then we,as theorists,should enlarge our mathematical knowledge with algebraic topology and homotopy just to KNOW what lies behind path integrals.
It's the for the reason of discovering path integrals,that Stephen Hawking thinks of Richard P.Feynman as the theorist of all time.
String theory is actually better defined mathematically in a sense than regular field theory, since it usually deals with 2d conformal field theory. Anyone who has ever worked on the subject knows that treating 4 dimensional lorentzian manifolds + quantum mechanics has unusually hard difficulties that aren't present in lower dimensions (and sometimes higher dimensions).
As a simple example, 2d field theories are nearly always resumable, so we have nice analytic results that make for interesting roundtable talks.
Feynman and path integrals
Feynman DID NOT invent path integrals. Path integrals are a way to sum a function which values every point in n-space when taking a particular path. That's what they are. Feynman used a different kind of integral, and the terminology's confused - the two types of path integrals don't mean the same thing.
The "reason" Feynman's approach works is 'cos he tried to generalise the classical mechanics path approach (Lagrangian) to quantum theory. And it worked. More or less.
And finally, to the n00b:
1. We first decide we want to know the probability that a particle goes from one point to another.
2. For each of the possible paths it could take through spacetime, we assign a little arrow (a complex number on the complex plane). And when we say all the paths are added, we put the little arrows tip-to-toe. The reason an infinity of paths can cancel is that if one arrow points to the left and the other points to the right, they add up to make nothing. That's how infinity paths cancel.
3. We find the length of the arrow of whatever's left over, and then we square it and then we get the probability of the particle going from that one point to the other.
We have not calculated the probability of a particle taking a particular path. We have calculated it going from one point to the other. If we want to know the probability of it going from A to C to B, we need to do those parts separately, then multiply and so on.
Do read QED, it's brilliant. Forget what Stephen Hawking thinks (well not everything he thinks) I think Feynman's one of THE greatest theorists for his path integral formulation of quantum mechanics.
You're thinking of line integrals or contour integrals. Integrating a value along a path. You're right that they're not the same thing as what Feynman used, but the term "path integral" does not mean line integral, it means Feynman's integrals over paths with a measure that's like "d(path)". You're not integrating along the paths but across different paths.
Technically, though, you're right. Feynman didn't invent them, Dirac did. Feynmanns insight was the big introduction of path integrals into pjysics.
masudr said:
Do read QED, it's brilliant. Forget what Stephen Hawking thinks (well not everything he thinks).I think Feynman's one of THE greatest theorists for his path integral formulation of quantum mechanics.
Thanks for quoting me.
:approve:
SelfAdjoint said:
Technically, though, you're right. Feynman didn't invent them, Dirac did. Feynman's insight was the big introduction of path integrals into pjysics.
And i got Pierre Ramond's book to show that Feynman didn't take those integrals out of the blue.
:approve:
I was watching Feynman's second lecture last night in which he talks all about the little arrows masudr mentions, here in the context of reflection, refraction, etc.:
http://www.vega.org.uk/series/lectures/feynman/index.php
  • · Replies 41 ·
  • · Replies 21 ·
  • · Replies 57 ·
