What is the impact of a cylinder on the force needed to tow a car up an incline?
  • Thread starter Thread starter Tycho
    Conceptual Force
The discussion centers on the impact of a solid cylinder on the force required to tow a car up a 23.1-degree incline. The cylinder, with a mass of 58.2 kg and a diameter of 0.211 m, is connected to a 1120 kg sedan via a chain. If the cylinder is oriented parallel to the incline, it does not affect the force needed to tow the car, as it merely rotates. Conversely, if the cylinder is oriented perpendicular to the incline, it acts as a pulley, increasing the force required due to the additional weight it supports.
  • Understanding of basic physics concepts, including force and tension.
  • Knowledge of inclined planes and their effects on force calculations.
  • Familiarity with rotational dynamics and the role of pulleys.
  • Basic understanding of mechanical advantage in towing scenarios.
  • Study the principles of torque and rotational motion in physics.
  • Learn about the mechanics of pulleys and their impact on force calculations.
  • Research the effects of incline angles on towing forces in automotive applications.
  • Explore real-world applications of mechanical advantage in towing and lifting systems.
Physics students, automotive engineers, mechanics, and anyone involved in towing operations or studying mechanical systems.
Tycho
Okay, I guess this is a conceptual problem that I am having with this one. let me explain the problem, firstly:
A sedan rolled off the road and needs to be towed. In order to get the car on the tow bed, it is pulled along an incline of 23.1 dgrees with a chain wrapped around a frictionless axle, composed of a solid cylinder of mass 58.2kg and a diameter .211m. The car has a mass of 1120kg.
a) find the forse required to pull on the chain in order that the car moves at a constant speed
b) find the tension in the chain.
Here's my problem:
We are pulling it up to the bed of the truck, and the chain is wrapped around a cylindar, then connected to the car. Does it matter that the chain is wrapped around a cylinder? wouldn't it just rotate? would that change the force needed to pull it up? This doesn't sound like a pulley to me, which is the only way i see it making a difference. I know this may seem like a weird question to a weird problem, but I'm just sitting here scratching my head unable to move forward! Haha, any help here would be appreciated!
How many times is the chain attached to the car? If it's only attached once, then there is no mechanical advantage due to the pulley. If the chain is attached to the car more than once - say a winch hooking from the car over the axle and back to the car - then there is mechanical advantage, and the tension will be smaller.
The impact of the cylinder on the force needed to tow a car up an incline depends on the orientation of the cylinder and how it is connected to the car. If the cylinder is oriented parallel to the incline and the chain is wrapped around it, then the force needed to tow the car will be the same as if the chain was connected directly to the car. This is because the cylinder will simply rotate as the car is pulled up the incline and will not affect the force needed to move the car.
However, if the cylinder is oriented perpendicular to the incline and the chain is wrapped around it, then the force needed to tow the car will be different. In this case, the cylinder will act as a pulley and will increase the force needed to move the car. This is because the chain will have to support the weight of the car as well as the weight of the cylinder, which will add to the overall force needed to tow the car.
In summary, the impact of the cylinder on the force needed to tow a car up an incline will depend on how it is oriented and connected to the car. If it is oriented parallel to the incline, it will not have an impact on the force needed, but if it is oriented perpendicular to the incline, it will increase the force needed due to acting as a pulley.
