Solving the Mystery of Racing Cans of Broth Down a Ramp
The discussion centers on the unexpected outcome of racing two cans of broth down a ramp, one frozen and one liquid. Despite mathematical predictions using the equation for a solid ring, V=sqrt[(4/3)gh], which suggested the frozen can would win, the liquid can outperformed it. Factors influencing this result include surface roughness of the frozen can, the lubricating effect of the liquid, and the initial velocity of the liquid can. The conversation also touches on the definition of translational kinetic energy, calculated as KE=1/2mv^2.
  • Understanding of kinetic energy equations
  • Familiarity with the concept of translational kinetic energy
  • Basic knowledge of friction and its effects on motion
  • Experience with experimental physics and data analysis
  • Research the effects of surface texture on friction in physics experiments
  • Explore the role of lubricants in reducing friction and enhancing motion
  • Study the principles of translational kinetic energy in greater detail
  • Conduct experiments comparing the motion of different fluids in similar scenarios
Physics students, educators, and hobbyists interested in experimental mechanics and the principles of motion and energy.
puravida
hey everybody, I am new to the forum, and glad to be here. looks like a great place for help when all has failed! :cry:
if you race 2 cans of broth down a ramp, one frozen and one still liquid, which one wins?
well, i did this mathematically, using the equation for a solid ring: V=sqrt[(4/3)gh] which i got from Kinetic energy equations, and the size and mass are irrelevant b/c they cancel out.
the result with this equation says that the frozen can wins, so i was very surprised to find the liquid can whipped the frozen can's butt on a piece of plywood in my backyard.
i have been looking for a way to get a solution through the use of Kenetic energy of: can, translational, and the soup. any help would be very much appreciated, b/c i am stumped. :confused: thanks.
also, for curious reasons, how would you define translational kinetic energy?
Hi there,
Welcome to the forum! It's great to see someone interested in solving this mystery. From your initial calculations, it seems like the frozen can should win since it has a higher velocity due to its lower density. However, as you observed, the liquid can actually won the race.
There are a few factors that could have influenced this result. First, the frozen can may have had a rougher surface which could have caused more friction and slowed it down. Second, the liquid inside the can may have acted as a lubricant, reducing friction and allowing it to slide faster. Third, the liquid may have also had a higher initial velocity due to its lower density and therefore less force needed to accelerate it.
In terms of kinetic energy, translational kinetic energy is the energy an object possesses due to its motion in a straight line. It is calculated using the equation KE=1/2mv^2, where m is the mass of the object and v is its velocity. In this case, the kinetic energy of the can would be equal to the kinetic energy of the soup inside.
I hope this helps in your quest to solve the mystery of the racing cans of broth down a ramp. Keep experimenting and analyzing, and you may find the answer you're looking for. Good luck!
  • · Replies 32 ·
