Classical mechanics with a mass on a light elastic string
The discussion revolves around a classical mechanics problem involving a mass attached to a light elastic string that is being pulled away at a constant velocity. The participants are tasked with determining the time intervals and distances involved as the string transitions from slack to taut and back to slack again.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the application of Newton's second law and the formulation of differential equations to describe the motion of the mass and the tension in the string. There are discussions about homogeneous and particular solutions to the differential equation, as well as the implications of initial conditions.
Several participants have provided insights into the formulation of the problem and the mathematical approaches being taken. There is ongoing exploration of the initial conditions and the implications of the string's tension on the motion of the mass. Some participants are questioning the relationship between the distances traveled by the mass and the end of the string, as well as the need to incorporate the length of the string into their calculations.
Participants are navigating the complexities of the problem, including the need to clarify assumptions about the motion of the mass and the conditions under which the string becomes slack. There is also a focus on ensuring that the derived equations align with the physical constraints of the problem.
*LouLou*
Classical Mechanics Homework question
Question - A light elastic string AB of natural length L and spring constant K, lies slack on a horisontal plane. A particle of mass m also at rest, is attached to end A of the string. The other end B is pulled along the plane with constant velocity V away from A in a straight line passing through A.
Find the time that elapses after the string first becomes taut until it becomes slack again.
Show that the particle will have traveled a total distance [itex]2L + V\pi({\frac{m}{k}})^{\frac{1}{2}}[/itex] by the time it catches up with end B.
Thoughts - I think I have to start with Newton's 2nd law, I'm just not sure what the force is a function of. I think it could be F(x) where x is the distance traveled but it can also depend on the speed that the string is being pulled so it would be F(V)?
If the force depends on the velocity of the end of te string then N's 2nd law would be
F(V) = ma = -Kx = m(dv/dt)
where v is the velocity of the particle at time t and V is the velocity of the end of the string. If I equate the two terms on the right I get...
-Kx = m(dv/dt) and if I rearrange this and integrate it I get...
t*(K/m)^0.5 = ln(x) + c
But I don't know where to go from here. I need to somehow eliminate x or t so that I only have 1 unknown. Or maybe I have to split the problem up into sections from the start and deal with separate parts?
When the string is on tension, [itex]m \ddot{x} = k (V t - x)[/itex], where [itex]x[/itex] is the position of the block. Rewrite equation of motion as [itex]m \ddot{x} + k x = k V t[/itex]. This is an inhomogeneous differential equation. So you look for a homogeneous solution and a particular solution: [itex]x(t) = x_h (t) + x_p(t)[/itex]. [itex]x_h(t)[/itex] is just the usual harmonic motion with two unknown coefficient. [itex]x_p(t)[/itex] is also very easy to find.
Once you write down [itex]x(t)[/itex], use the initial conditions to solve for the two unknown coefficient. The string loses tension, when [itex]Vt -x < 0[/itex]. This condition allows one to solve for t.
So I did what you said and used m(dv/dt) = K (Vt-x) to generate the differential equation
m(d^2x/dt^2) + Kx = KVt
The homogeneous solution that I got is
xh(t) = Asin(t(K/m)^0.5) + Bcos(t(K/m)^0.5)
I found the particular solution by guessing the solution for x to be of the form
x = bt^2 + ct + e
resulting in a particular solution of
xp(t) = Vt
So the general solution is
x(t) = Asin(t(K/m)^0.5) + Bcos(t(K/m)^0.5) + Vt
I'm not sure about the initial conditions, the only one I can see is that when t=0 the velocity of the particle is also v=0 so B must be 0.
so the general solution becomes
x(t) = Asin(t(K/m)^0.5) + Vt
That is as far as I can get without figuring out a second boundary condition. Does this look like it's on the right track?
Thanks very much for all your help!
The particle started at rest, so [itex]x^{\prime}(0) = 0[/itex].
Oh of course thank you!
So A is
[itex]A = -V\sqrt{\frac{m}{K}}[/itex]
So the general solution becomes
[itex]x(t) = Vt - V\sqrt{\frac{m}{K}} sin (\sqrt{\frac{m}{K}} t)[/itex]
So after I've figured out the time taken for the string to become slack, I figured that the total distance traveled until the mass gets to point B will be L+Vt=x which rearranges to get [itex]t = \frac{x-l}{V}[/itex]
is this along the right lines for the second part?
Thanks!
So A is
You inverted the k and the m in the sine. It's convenient to write [itex]\omega=\sqrt{\frac{k}{m}}[/itex], and write:[itex]x(t)=V t - \frac{V}{\omega} \sin(\omega t)[/itex]
Do you think the answer should depends on the length of the string?
Ok, so our answer for [itex]x(t) = Vt - \frac{V}{\omega } sin (wt)[/itex].
So assuming that at the instant the string looses tension the following is true
[itex]Vt-x=0[/itex]
we can replace Vt with x in the equation for x(t) and after some cancelations figure out that
[itex]sin(wt) = 0[/itex]
So [itex]wt = n\pi[/itex]
Assuming that when the string loses tension for the first time n=1 then
[itex]t = \frac{\pi }{\omega } = \pi\sqrt{\frac{m}{K}}[/itex]
To find the distance traveled I assume that all we need to do is substitute in t into the equation above. In which case it does depend on L because the mass has to travel the length of the string to catch up with point B?
So I've been working on this problem a bit more... I've been trying to find the total distance adding the distance taken for the string to become slack x(t), when
[itex]t = \pi\sqrt{\frac{K}{m}}[/itex] to the distance traveled by the point B [itex]x = Vt_{2}[/itex] and then adding the length of the string to that giving me...
[itex]x = V\pi\sqrt{\frac{K}{m}} + L + Vt_2[/itex]
From the answer that we are given:
[itex]x = V\pi\sqrt{\frac{K}{m}} + 2L[/itex]
it's clear that [itex]Vt_2[/itex] should equal L, but I'm unsure how to show it.
Thanks a million for your help so far!
[itex]x[/itex] is the displacement of particle B. Why is there a need to add [itex]L[/itex] to it?
You are right that string loses tension at [itex]t_1 = \frac{\pi}{\omega}[/itex]. So the distance traveled is [itex]x(t_1) = V t_1 = \frac{\pi V}{\omega}[/itex].
I think we need to add L because the question requires that we find the displacement of the mass when it catches up with the end of the string, which is L distance away from the other end of the string where the mass is attached. Since we've got the time taken for the string to slacken again, the corresponding distance can be calculated, and this distance added to L will give us the displacement at point B. I hope my logic is correct.
Oops, didn't read the question right. Then you just need to find the speed and distance when the string lost tension and just add the catch up time.
  • · Replies 27 ·
