Calculating Strain in a Steel Cable Supporting a Freight Elevator
The discussion revolves around calculating the strain in a steel cable supporting a freight elevator, which is loaded with additional mass and descending at a constant speed. Participants are exploring the concepts of tensile strain and stress, as well as the implications of the elevator's motion on these calculations.
  • Mixed
  • Participants discuss the definition of strain and its types, questioning whether the problem is asking for strain or stress. Some suggest deriving relationships based on assumptions about the cable's volume and properties, while others express confusion about the relevance of the elevator's speed in the calculations.
There are various lines of reasoning being explored, with some participants offering guidance on how to approach the problem using known values like the diameter of the cable and Young's modulus. However, there is no explicit consensus on the correct interpretation of the problem or the calculations involved.
Participants note the absence of an initial length for the cable, which raises questions about the assumptions being made. There is also mention of potential typos in the problem statement, leading to uncertainty about the expected calculations.
Tycho
A 1260kg freight elevator is supported by a steel cable of diameter 34.9mm. It is loaded with a crowd of people collectively having a mass of 2850kg and it is descending.
a) What is the strain on the cable while the elevator is descending at the constant speed of 2.30 m/s?
b) What is the strain in the cable when it is brought to a stop in 0.600s?
okay this doesn't seem to be very hard, but as i tried to do it, i just keep getting stuck.
okay firstly: strain.
i only know of 2 types of strain: tensile, and shear. this definitely isn't a shear strain problem since the force applied is not directed parallel to the surface.
that leaves tensile strain. Tensile strain is (the change in length in response to applied stress) / (relaxed length) is it not? But if this is what i am supposed to use, shouldn't the problem have given me an initial legth of the cable? This leads me to believe that i am confused on the concept of strain. Is there a different type of strain that i am missing, or should there be another step?
Thanks physics gurus!
The questions make more sense if you regard "strain" as a typo; I think it must be the stress they're after.
Otherwise, they would have needed to give you a stress/strain-relationship+initial length.
However, they just MIGHT be mean to you, and assume you find out the particular relationship in that case.
In order to proceed then, you should derive a relationship between relative longitudinal strain, and relative radial strain.
Hint: This can be done by assuming that the cable's volume must be constant!
Rewrite the appropriate Hooke's law using the relative radial strain instead.
Likewise ... the problem sounds pretty basic in order to focus on strain. Thinking the problem axisymmetric makes it easy to work out in such a case no matter.
relative radial strain?
Hookes law= Y (Change in length in response to applied stress / relaxed length) where Y= Young's modules
I must have the wrong Hookes law. This just works to take the same problem into a different equation? (i don't know the initial length of the cable.)
It could be a typo... but i don't want to trust my grade on a typo, y'know? any other suggestions?
You do not need initial length for this problem.
You know the diameter of the cable ...
Compute Area , Acceleration,Force , Stress ... etc
For constant speed there is no acceleration (or acceleration = 0 )
Tensile Stress = (Axial Force) / (Cross- Sectional Area)
Modulus of Elasticity = Stress / Strain ( this is hooke's law)
For Steel the modulus of elasticity = 200 GPa (approx. or u can use 207 GPa)
Then compute Strain
If you assume that the volume of the cable is constant, with unkown length L, KNOWN radius R (you have this one!), then:
[tex]V=L\pi{R}^{2}=\pi(L+\delta{L})(R-\delta{R})^{2}[/tex]
Or:
[tex]1=(1+\frac{\delta{L}}{L})(1-\frac{\delta{R}}{R})^{2}[/tex]
We assume:
[tex]\frac{\delta{L}}{L},\frac{\delta{R}}{R}<<1[/tex]
Multiplying the brackets out, and neglecting products of small terms, yields:
[tex]1\approx1+\frac{\delta{L}}{L}-2\frac{\delta{R}}{R}[/tex]
Or:
[tex]\frac{\delta{R}}{R}=\frac{1}{2}\frac{\delta{L}}{L}[/tex]
Okay, I did like you suggested, but nowhere in my work did i factor in the speed at which the elevator was moving?
here's my work:
(1260kg+2850kg)*9.81 = 40319.1 Newtons
R=17.45
Cross-sectional area of the cable = 2piR = 2pi*17.45 = 109.64mm = .10964m
Tensile Stress = (axial force) / (cross-sectional area) = 40319.1 N / .10964m = 367740.788 Pa
Young's Modulus for steel = 20*10^10 = Stress/Strain
20*10^10 = 367740.788 Pa / Strain
Strain = 367740.788 Pa / 20*10^10
Strain = 1.83*10^-6?
That number MUST be wrong? did i make a mistake, or is the process incorrect?
Again, where am i supposed to account for the speed at which the elevator is moving? (I.E. the second problem)
ooooops
cross sectional area = Pi * Radius^2
Or:
We assume:
Or:
Wow, this went way over my head! lol. Is this the derivation of the relationship you were talking about? If so, then (since it looks unfamiliar) i would assume this isn't wasn't what my instructor was looking for?
You bet that's not what he asked you for if you haven't seen it before.
Stick with what the other poster is doing; the fact that you in a) seems to get a tiny strain is simply because steel hardly lengthens.
and you should also know:
Summation of Froces(using directions) = Mass * Acceleration
and the v = u - at ( calculate the acceleration, v = 0 , t = 0.6 sec)
ashfaque said:
ooooops
oops! haha i knew that!
Strain = 2.11*10^13
That's more like it, but is it right?
And what about the speed of the elevator? If this is the answer to part a, then how do i solve for b?
part a)
M = 1260 + 2850 = 4110
F = M*g = 4110 * 9.81 = 40319.1 N
A = pi * dia ^2 / 4 = 9.566E-4
stress = F/A = 42.147E6 Pa
Strain = stress / Y = 42.147E6 / 200E9 = 2.1E-4
ashfaque said:
part a)
A = pi * dia ^2 / 4 = 9.566 ^ -4
stress = F/A = 42.147 ^ 6 Pa
Strain = stress / Y = 42.147 ^ 6 / 200 ^ 9 = 2.1 ^-4
A= pi * dia ^2 / 4 = 9.566 ^ -4 ??
shouldn't it be:
A= pi * 34.9mm^2 / 4 = 956mm = .956m ?
stress = F/A = 4.21 * 10^4 Pa ?
Young's modulus = stress/strain
strain = stress / young's
strain = 4.21*10^4 / 20*10^10 = 2.105 * 10 ^ 13 ??
or did i screw it up again?
shouldn't it be:
hmm
34.9mm^2 = (34.9mm)^2 = (0.0349 m) ^ 2 = 1.218E-3 (metre squared)
1.218E-3 *Pi/4 = 9.566E-4 (metre squared)
hey Tycho .. i joined here today .. u?
I saw what you did in the last one. Area=pi * R^2. you used the diameter instead of the radius. Welcome to the physics forum! this is my second month on.
do you know how to take the speed of the lift into effect?
ooops on the diameter matter :)
initially moving in a constant speed 'u ' the elevator stops
that means 'v' = 0 ...
noy from v = u - at ( a = acceleration)
we get a = u/t
Mass * a = Summation of forces (vector addition)
no oooops ...
Radius^2 = (Diameter)^2 / 4
(R)^2 = (D/2)^2 = D^2 / 4
we get a = u/t
you're going to have to put these two things together for me. how would i put this summation of forces into the equaition for strain?? therein is my biggest problem!
Tesnsion+Weight (with direction) = Summetion of forces
u know weight
and also Mass*a ...
figure out Tension , that's the force to calculate stress ... then do like as (a) ..
i have to get my semseter results today ... got to sleeep (i live in another part of the world)
pray .. okay
9K
