| New Reply |
Could cell phone technologies be used to send signals to other modified cell phones? |
Share Thread | Thread Tools |
| Jul28-11, 07:19 PM | #1 |
Hypothetically, could the transmitter-receiver systems in cell phones communicate directly among other such systems at a range comparable to the range they can communicate with towers?
With 4G bandwidth? |
| Jul28-11, 09:57 PM | #2 |
I have wondered the same thing.
My first guess would be NO because the transmit and receive frequencies would be different. |
| Jul28-11, 11:07 PM | #3 |
Even if you matched the frequencies, the cell phones' very low power transmitters would make such an arrangement worthless.
It's not even worth discussing all the necessary changes to the phone's firmware. |
| Jul29-11, 02:33 AM | #4 |
Ask such questions at engineering subforum!
Yes, they could communicate directly, just two issues: 1. it would be pretty difficult to modify any commercially available phone to do so, as the low level protocols are hardwired in their chips; 2. in most countries it would be not only illegal, but really prosecuted, as interferring with operating cell-phone system. |
| Jul29-11, 04:27 AM | #5 |
a walkie-talkie function is built in to some cell phones.
I always wanted one but could never find one. (not that I really looked that hard since I cant really afford one anyway) I was surprised that they would sacrifice one of their frequencies for this. the downside is that it isnt private |
| Jul29-11, 04:51 AM | #6 |
| Jul29-11, 05:07 AM | #7 |
I dont understand most of this:
http://en.wikipedia.org/wiki/Push-to-talk Push to Talk over Cellular (PoC) is a service option for a cellular phone network which permits subscribers to use their phone as a walkie-talkie with unlimited range. A typical Push to Talk connection connects almost instantly. One significant advantage of PoC / PTT is that it allows a single person to reach an active talk group with a single button press; users need not make several calls to coordinate with a group. Push-to-talk cellular calls similarly provide half-duplex communications — while one person transmits, the other(s) receive. This combines the operational advantages of PTT with the interference resistance and other virtues of mobile phones. Traditional mobile phone networks and devices utilize full-duplex communications, allowing customers to call other persons on a mobile or land-line network and be able to simultaneously talk and hear the other party. Such communications require a connection to be started by dialing a phone number and the other party answering the call, and the connection remains active until either party ends the call or the connection is dropped due to signal loss or a network outage. Therefore, the telephone communication protocol does not allow for casual and immediate transmissions to be sent to other parties on the network. While telephone calls require the lengthy process of dialing, network switching and routing, call setup, and waiting for the other party to answer, a two-way radio has a much quicker protocol because of the immediacy of push to talk communication. Later versions of PTT are based on 2.5G or 3G packet-switched networks and use SIP and RTP protocols. These particular versions of PTT are called Push to Talk over Cellular, which is abbreviated PoC. When used with GSM and CDMA networks, the PTT service commonly does not use up the regular airtime minutes that are available for general voice calls. |
| Jul29-11, 05:09 AM | #8 |
"Really direct" communication between handsets is not supported by any of [ADDED: civilian] mobile standards, except of DECT (short distance system - few hundred meters - used for communication between your fixed line phone and wireless handsets for home and office use). DECT standard allows for direct pairing, and operates in unrestricted radio band, so many DECT handsets (e.g. Siemens Gigaset, I use...) support it. You may take a pair of handsets from your home for a picnic and talk in a walkie-talkie mode, even if handsets are out of range of your base station. ADDED: I've forgotten: Most of restricted use cellular systems (e.g. TETRA used by police, firemen, medical emergency, etc. in Europe) support direct communication between phones. But, to avoid interference, they switch to direct communication only if base station is not in range. |
| Jul29-11, 06:55 AM | #9 |
| Jul29-11, 06:56 AM | #10 |
| Jul29-11, 07:16 AM | #11 |
Problem is that the protocols are asymmetric (e.g. most control functions, like assigning timeslots for transmission are performed only by BS). So you could use only the very lowest layers of communication: radio electronics and modulators, but the transmission control, coding, encrypting, transmission power adjustment, error detection/correction, etc - would have to be implemented by you. I missed that your question: Max distance for handset-handset communication for TETRA in open area is 3-5km, while handset-BS is up to 25-40km (anyway BS grid is usually below 20km even in wilderness, much more dense in urban areas) |
| New Reply |
| Thread Tools | |
Similar Threads for: Could cell phone technologies be used to send signals to other modified cell phones?
| control a motor remotely with cell phone signals | Electrical Engineering | 15 | ||
| Could cell phones act as cell phone relay towers in an emergancy? | Electrical Engineering | 7 | ||
| Cell Phones | General Physics | 15 | ||
| Cell phones can pop your popcorn for you!!! | General Discussion | 30 | ||
| Speaking of cell phones... | Computing & Technology | 3 | ||
