How Far Does the Block Travel After Being Struck by the Bullet?
  • Thread starter Thread starter pkhor
The discussion focuses on calculating how far a block of wood travels after being struck by a bullet. A 0.010-kg bullet traveling at 400.0 m/s embeds itself in a 4.0-kg block at rest. The momentum conservation principle is applied to find the final velocity of the block and bullet system, which is calculated to be 0.9975 m/s. To determine the horizontal distance the block travels before hitting the floor, projectile motion equations are utilized, specifically involving the time of fall and the distance formula.
  • Understanding of momentum conservation principles
  • Basic knowledge of projectile motion equations
  • Familiarity with kinematic equations
  • Knowledge of gravitational acceleration (9.8 m/s²)
  • Study the conservation of momentum in inelastic collisions
  • Learn about the equations of motion for projectile motion
  • Explore kinematic equations for calculating distance and time
  • Investigate real-world applications of projectile motion in physics
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of collisions and projectile motion.
pkhor
the original problem:
A 0.010-kg bullet traveling horizontally at 400.0 m/s strikes a 4.0-kg block of wood sitting at the edge of a table. The bullet is lodged into the wood. If the table height is 1.2 m, how far from the table does the block hit the floor?
this is what i did:
lets the mass of bullet = m2
the mass of block of wood = m1
velocity of the block of wood before the collision take place = v1
velocity of the bullet = v2
velocity of the block and bullet after the collision take place = vf
momenta of the block = p1
momenta of the bullet = p2
the momentum of block and bullet after collision equals the sum of momenta of the block and the bullet before the collision:
pf = pi
The initial momentum is the sum of the momenta of the block and bullet
pf = p1 + p2
Since the block is initially at rest, p1 = 0. Then
pf = p2
or
(m1 + m2)(vf) = (m2)(v2)
Solving for vf:
vf = [(0.010)(400.0)]/(4.0+0.010) = 0.9975 m/s
And I stuck here because I didn't know how to calculate the distance from the table to the point that the block hit the floor.
Am I have to use the projectile motion concept?
Your help would be highly appreciate.
Yes, you have to use the projectile motion formulas.
Yes, you will need to use the concept of projectile motion to calculate the distance from the table to the point where the block hits the floor. Here are the steps you can follow:
1. First, you need to determine the initial velocity of the block, v1. Since the block is initially at rest, its initial velocity will be 0 m/s.
2. Next, you can use the equation of projectile motion to calculate the time taken for the block to hit the floor. The equation is t = 2v1/g, where v1 is the initial velocity of the block and g is the acceleration due to gravity (9.8 m/s^2).
3. Once you have the time, you can use the equation s = ut + 1/2at^2 to calculate the distance traveled by the block before hitting the floor. Here, u is the initial velocity, t is the time, and a is the acceleration due to gravity.
4. Finally, you will have the distance from the table to the point where the block hits the floor. You can subtract this distance from the height of the table (1.2 m) to get the final answer.
I hope this helps! Let me know if you have any other questions. Good luck!
