Einsteins Brain and Human Intelligence
The discussion centers around the relationship between brain structure, specifically the density of neural connections, and human intelligence, using Einstein's brain as a reference point. Participants explore the complexity of intelligence beyond mere cellular miniaturization and density, considering various factors that may contribute to cognitive abilities.
  • One participant questions the simplification of intelligence to just the miniaturization of cells and density of connections, suggesting that factors like the efficiency of neural connections are also important.
  • Another participant proposes that while density might influence the likelihood of achieving intelligence, it may not directly correlate with what is traditionally understood as intelligence, emphasizing the role of hypothesis formulation in intelligence.
  • The discussion touches on the nature of NP-Complete problems in computer science, suggesting that intelligence involves navigating complex problems, where luck and hard work play significant roles.
  • A different participant challenges the notion of a "cognitive peak of evolution," asserting that such a concept does not exist.
Participants express differing views on the factors contributing to intelligence, with no consensus reached on the relationship between brain structure and cognitive abilities. Some participants challenge the framing of intelligence, while others explore its complexities.
Participants reference various interpretations of intelligence and the complexity of cognitive processes, indicating that the discussion is nuanced and dependent on individual definitions and assumptions.
bugatti79
Folks,
I read an article in the Sunday Times as attached. How does this compare against the outcome of the autopsy performed on Einsteins brain?
The article seems to be implying intelligence depends on only the miniaturisation of cells and the density of connections. Surely the evolution of brain intelligence is more complex than that, i.e, the efficiency of neural connections or what have you etc etc
Can anyone comment?
Cheers
Biology news on Phys.org
It seems plausible that density might be a factor, even if only as a result of probabilities. It could increase the likelihood of the brain entering a state that "yields" intelligence but i would be surprised if it played a direct role in what we identify as intelligence.
For example, when Einstein formulated his theory of relativity, computationally speaking, he solved an instance of a problem of the form "given X data, identify the process that produced X or a significant portion of X" (where "significant" varies with the context).
There are different interpretations of "intelligence", but we tend to associate the ability to successfully formulate a hypothesis that describes a given process/state, with intelligence.
Given some data, we can arrive at a suitable hypothesis by trying out all the possible explanations and picking the one that works the best. Of course this isn't realistic for either computers or brains because of the volume of possibilities that would have to be explored.
In computer science these types of problems are commonly occurring yet intractable problems called NP-Complete problems. One example is Subset-Sum: given n numbers determine if there exists a subset of the n numbers that adds up to zero.
Luck is a factor in solving these problems. You may randomly pick the only subset, of 1000 numbers, out of a million, that adds up to zero right on the first attempt. That's like solving the Riemann Hypothesis by saying the first thing that you think of.
The fact that NP-Complete problems are not efficiently solvable (pending proof of P != NP) means that no one, not even a super quantum computer, has an algorithm that enables them to effortlessly arrive at a Theory of Relativity or a Theory of Everything or a solution to the Riemann Hypothesis.
In effect, hard work and occasionally a little luck are the biggest contributors to intelligence, more so than innate ability, as long as you're able to tune your attempts and avoid repeating mistakes. Without hard work you're only intelligent if you're really lucky (and the former is much more admirable).
This thread doesn't meet our criteria for posting.
