Potential Difference across capacitors in parallel.
The discussion revolves around two capacitors connected in parallel to a 12-V battery, specifically focusing on calculating the equivalent capacitance, charge on each capacitor, potential difference across each capacitor, and energy stored in each capacitor.
  • Participants explore the relationship between charge, capacitance, and voltage, questioning the assumptions made regarding the potential difference across the capacitors.
There is an ongoing exploration of the definitions and relationships between charge, capacitance, and voltage. Some participants provide guidance on understanding the potential difference in parallel circuits, while others seek clarification on specific calculations and assumptions.
Participants are discussing the implications of the voltage across capacitors in parallel and the definitions involved in the equations presented. There is a noted emphasis on not editing previous posts, indicating a focus on maintaining the flow of discussion.
OUmecheng
Two capacitors, C1 = 20 micro Farads and C2 = 5 Micro Farads are connected in parallel and the resulting combination is connected to a 12-V battery. Find (a) the Equivalent capacitance of the combination, (b) the electric charge on each capacitor, (c) the potential difference across each capacitor, and (d) the energy stored in each capacitor.
Ceq = C1 + C2
Q = CV
Ec = QV/2 = (C(V^2))/2 = (Q^2)/2C
(a) 2.0x10^-6 F + 5x10^-6 F = 2.5x10^-5 F(b) Q = CV,
Q1 = (20x10^-6 F)(12V) = 2.4x10^-4 C
Q2 = (5x10^-6 F)(12V) = 6x10^-5 C(c) Not quite sure what this is asking for?(d) Ec = CV^2/2
Ec1 = c1V^2 / 2 = 0.00144 F*V^2
Ec2 = c2V^2 / 2 = 3.6x10^-4 F*V^2
As you can see I've worked most of this out, seems simple enough, but I don't know what to do for (c)?
It's simpler than you think. Draw yourself the circuit and look at it.
errrr charge over capacitance?
How did you do part (b)? What voltage did you assume across each capacitor? :rolleyes:
Please don't edit previous posts. Just post a new response.
Your "attempt at a solution for (b) says
(b) Q = CV,
Tell me in English what do the numbers highlighted in red represent?
(b) Q = CV,
Battery Voltage/Potential Difference?
It is not a ratio. In plain English the equation Q = CV means
The charge on a capacitor is the same as the capacitance multiplied by the potential difference (or voltage) across the terminals of the capacitor.
Can you answer (b) now?
So the potential difference is the same as charge on a capacitor divided by the capacitance.
V1= Q/C1
V2= Q/C2
Thanks!
Actually, you are doing it backwards. Memorize this definition
"Two circuit elements in parallel share the same potential difference (or voltage) across their terminals"
and use it constructively.
Cheers.
  • · Replies 30 ·
